Old 11-18-2010, 10:51 PM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
Steering shaft shortening?
I swapped cabs from a later model with no power steering and the shaft that goes from the column to the steering box is a couple inches big, is it possible to take this apart and cut it down to size? I loosened this one bolt but didnt want to break anything with knowing...
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 11-18-2010, 10:58 PM   #2
Piece of Work
Cultural Infidel
Piece of Work's Avatar
Re: Steering shaft shortening?
check this thread, start at post 41, hopefully this helps.
http://67-72chevytrucks.com/vboard/s...=191143&page=2
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 11-18-2010, 11:25 PM   #3
Wildstreak
Wildstreak's Avatar
Thanks that looks like it will help, Ill try and see what I can do in the morning.
57 chevy 4x4
68 burb 2wd:
Old 11-18-2010, 11:40 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Here are a couple of threads that might have some info you can use also...
http://67-72chevytrucks.com/vboard/s...d.php?t=133937
http://67-72chevytrucks.com/vboard/s...d.php?t=210459
LockDoc
Leon
Old 11-21-2010, 02:05 PM   #5
Wildstreak
Wildstreak's Avatar
Thanks LockDock I drilled out the plastic and it still wouldnt budge, then I hammered like you said and it slid up real nice.
One more question tho, when you put the steering wheel back on, do you use the nut that holds it on to pull the wheel on as well?
57 chevy 4x4
68 burb 2wd:
Old 11-21-2010, 08:52 PM   #6
LockDoc
LockDoc's Avatar
No problem.
Yes, that has always worked for me....
LockDoc
Leon
