Old 11-18-2010, 11:41 PM   #1
smn69
69 is going back together
Just finished painting my 69 last night. Spent a couple hours tonight putting it back together. After 3 years, it is fun to see it becoming a real truck again. Here is a quick overview:
4/6 drop, 17x8 steel craigar wheels 275 60 in the rear and 235 60 in the front
Front disc brake conversion
Front sway bar, new bushing all around, and new body mounts
New u-joints and carrier bearing
Poly blazer tank out back
Completely rebuilt 307 (original motor) with 3 spd manual
Motor has edelbrock cam, intake, and carb. and Summit roller rockers.
New fuel pump, headman full length headers, and electric fan conversion
Electronic ignition in stock distributor
Dual exhaust with H pipe and exiting in front of the tires
The paint is Summit Racing single stage Ultra Blue Pearl with clear coat on top
New red oak and stainless bed strips in the back
I have done all the work myself (with help from my 16 year old daughter) and it has been a real learning experience. This has been my first attempt at body work and painting (hence the night pictures ). I am looking forward to getting it on the road and having some fun driving it (when I can get the keys away from my daughter!)
Still some work to do, but I have all the parts I need and it should be road worthy in a couple of weeks. More pictures to come! (I may even get brave and take some in the daylight).
smn69 is offline   Reply With Quote
Old 11-18-2010, 11:56 PM   #2
Putter
More Cowbell....
Putter's Avatar
Re: 69 is going back together
Looking good.
Just one concern....I have seen many MANY guys express concern over that particular air filter. If the truck should backfire thru the carb, the foam filter can very easily catch fire and ruin all your efforts.
Just my $0.02
Other than that, it looks killer. Give each other a pat on the back!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 11-18-2010, 11:59 PM   #3
smn69
Already knew that and a new filter is on the top of the list before it hits the road. Thanks for the heads up though, i appreciate it!
Old 11-19-2010, 12:44 AM   #4
QKENUF4U
QKENUF4U's Avatar
good job.... good luck getting your keys away from the daughter....
QKENUF4U is offline   Reply With Quote
