Old 11-19-2010, 01:52 AM   #1
djw32
Window felt install?
Anybody have a tip or trick to install window felt on a 1970 chevy c-10?
djw32 is offline   Reply With Quote
Old 11-19-2010, 02:26 AM   #2
tonypaul
tonypaul's Avatar
Re: Window felt install?
I bent the center tabs out just a little bit on all of them, got the felt to were almost all the tabs were lined up with the holes and just started popping them in. I just did both doors other day along with all new vent window seals and channel felts- it all went way to easy... I was really worried from what I had read that it was a tough job.
tonypaul is offline   Reply With Quote
Old 11-19-2010, 06:24 AM   #3
JimKshortstep4x4
What works for me is to get someone to help install them. One person on each side of the door. For example, when installing the outer fuzzie, the person on the outside does the installing while the person on the inside makes sure of the alignment of the clips. A flashlight makes it easier to see that the clips are starting into the holes. If you miss a hole, that is when trouble starts!
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-21-2010, 03:36 PM   #4
djw32
I will try to figure something out.
thanks
