Old 11-19-2010, 01:05 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
How much lift for 36/37's?
How much lift does an M1008(RCLB) need to clear 36/37"(Hummvee)tires? Obviously it would need new wheels that are 16.5. Thanks.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 11-19-2010, 02:11 PM   #2
Davidmichael
Davidmichael's Avatar
Re: How much lift for 36/37's?
to clear with decent trimming, 4 inch lift
to clear with minor trimming 6 inch
to clear and have stock sheet metal 8 inch.
That's just IMO also. any others can chime in.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 11-19-2010, 03:05 PM   #3
cur88alan
you could also do like a 6 in suspension lift and 2 in body lift i have a 8 in suspension lift with 2 in body and there is tons of room for my 39.5s
cur88alan is offline   Reply With Quote
Old 11-22-2010, 11:07 PM   #4
phx 4x4
phx 4x4's Avatar
my 73 has 38 in 15.5 wide with a 6in lift no trimmin and never have rubbed
Built not Bought
phx 4x4 is offline   Reply With Quote
Old 11-23-2010, 12:36 AM   #5
MTCK
MTCK's Avatar
That's ~8" on the blazer with 36x12.50 tsl radials. I think 6" would work no problem. I prefer something lower and trim with good bump stops if you're really going to wheel it. You could make 4" work if you don't mind getting the sawzall out. 6" would be a good compromise.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-24-2010, 06:16 PM   #6
19724x4plowboy
19724x4plowboy's Avatar
I have a 6" on my 72 with the 37" tires you are talking about on it. It's fine on the road but will rub when wheeling.
19724x4plowboy is offline   Reply With Quote
Old 11-24-2010, 07:18 PM   #7
Psycho71
Psycho71's Avatar
Been bouncing around the same question in my mind lately. Gonna be doing the lift on my burb before long, and am trying to decided whether or not I wanna trim for the 36's. I think, since I'm gonna have to paint it anyway, I'll go with a 4" lift and do some trimming. But still kinda on the fence between 4" and 6" of lift.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
