Old 11-19-2010, 02:04 PM   #1
lt704
charging issue ??
Hi Folks, My 2003 Chevy Silverado starting giving me problems the other night. It was a bad alternator. The truck kept dying. I put in a new alt. because the old one was not charging. The truck runs fine ( not dying ). The problem I am having as I drive the the heater blow almost dies when i hit the brakes but runs normal as i drive with increased speeds, the same is tru with my powere windows. I checked my battery, It is good and also good underload. My alt is reading 14+ volts when truck is running ( with battery/alt tester ) My truck has the 4.8 engine and a 105 amp. any ideas??? thank You Russ
lt704 is offline   Reply With Quote
Old 11-22-2010, 01:11 PM   #2
rwolf9653
more ideas than money
rwolf9653's Avatar
Re: charging issue ??
I would check the cables leading from the battery and to the starter. It sounds like they are connected, but not allowing enough electricity to flow freely through them. This could happen from rust and corrosion increasing the resistance through the wires.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 11-23-2010, 01:45 PM   #3
Warrens69GMC
Warrens69GMC's Avatar
Check your idler and your tensioner pulleys, if one is starting to bind you will have the same symptons.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 11-24-2010, 03:38 PM   #4
lt704
I appreciate the information I will check theese out, thank you Russ
Old 11-28-2010, 08:31 PM   #5
lt704
Hi folks, The problem has been fixed. It was indeed the battery to starter cable. It was loose and had junk on it. thanks for all the help
