Old 11-19-2010, 10:23 PM   #1
jared87350
87 350 TBI guys help!!!
my ignition control mod keeps going out.
its becoming a pain.
what could be the prob???
thanks
jared87350 is offline   Reply With Quote
Old 11-20-2010, 08:15 AM   #2
D13
D13's Avatar
Re: 87 350 TBI guys help!!!
1. Check your ground cables and the wires going to the module. It is not uncommon for thse wires to crack / break /short which can shorten the life of a module.
2.Replace your plug wires. If one is bad it will pulse back and eventually short out your module.
3. If you have a repeat problem use ONLY GM / Delco modules. Aftermarket ones are cheaper primarily because they delete the over voltage protection circuits.
My 1990, I put a set of Accel wires on it, it then ate a module and a coil every 20k miles until I put a set of Delco factory wires on, and a Delco module. 50k miles with no more issues.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 11-20-2010, 02:28 PM   #3
jared87350
thanks for the advice.
Old 11-20-2010, 03:23 PM   #4
jared87350
could it passibly be the ignition coil?
could a bad coil stop the whole ignition curcuit?
including the injectors?
Old 11-20-2010, 05:03 PM   #5
wyattglock
wyattglock's Avatar
It could be an ignition coil. I have a similar problem with my 454 tbi. I have replaced the plugs, wires, and ignition module. That seemed to help a lot. I tried swapping my friends coil from his 87 Jimmy onto my truck and that smoothed it out all together. So this week I am going to replace the coil and go from there.
wyattglock is offline   Reply With Quote
Old 11-20-2010, 09:40 PM   #6
hugger6933
GM had a recall on the 87's becasue of a dist oil problem. the oil wick in the shaft had some design flaws [best I can remember]. Not to overlook anything simple you are putting the grease under the module? I have always been told that will lend to overheating problems. Jim
hugger6933 is offline   Reply With Quote
Old 11-20-2010, 10:24 PM   #7
jared87350
i replaced the ignition mod today and put the white grease under it.
having the same problem. no start. the injectors are not pulsating eather.
i replaced the igniton mod yesterday as well and seamed to fix the problem; then on the freeway it dies with no symptom leading up to it.
it has to be something that is tying the injectors with the ignition.
all powers and ground have been look over. unless somehow i missed one or two.
if its not the ignition mod being bad; what could it be?
any advice would be great.
i am out of ideas .all sensors have been replaced as with the ECM.
this problem seeme to be off and on recently; now it just dosnt start.
Old 11-21-2010, 08:01 AM   #8
D13
D13's Avatar
Injection is based on seeing ignition pulse. No pulse, no signal to ECM, no injection.
Pick up coil in the distributor? If you have a AC voltmeter, unplug the pickup coil from the module and watch for AC voltage on the coil as you crank. If the coil isn't producing voltage the module doesn't produce a signal.
1987 2 ton
Old 11-21-2010, 09:45 AM   #9
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I had a TB 350 in my 72 for a while, It started to eat the modules and I replaced the distributor and it stopped for at least 25k more miles until I traded the truck off. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 11-21-2010, 02:07 PM   #10
jared87350
bump for help
Old 11-21-2010, 02:30 PM   #11
jared87350
can a bad spark control mod cause a no start??
Old 11-22-2010, 02:07 AM   #12
rfmaster
rfmaster's Avatar
Yes, it can - especially with after market coils. In your case I would strongly recommend replacing reluctor coil (or getting rebuilt distributor all together). Reluctor coil picks-up magnetic flux variation induced by rotor cage. I have seen magnets go bad with age (loosing magnetism due to repeated heat cycling). Since relucotor coil supplies pulses to ignition control module (ICM) your troubles may appear as ICM failure when the real problem is with reluctor coil or rotor wheel. It is worth a check - check coil resistance - it should be between 500 and 1200 Ohms.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
