11-20-2010, 12:25 AM | #1 |
Alright Alright Alright
Ignition Coil Overheating?
I use my truck to do deliveries at my place of work and I drive it a good bit in a day (lots of starts also). Every once in a while, the truck will not start and just turn over. When this happened tonight, I had my timing light with me. I hooked it up and no flash. I poured a cup of water over the coil (HEI) and then sprayed a little carb cleaner to dry it off. It started right up. It happened again later on and this time, it wouldnt start. I had to let it sit for an hour. What could be causing this? How can I keep this thing cool? The coil is only a month old and the last coil did the same thing.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
11-20-2010, 12:46 AM | #2 |
Re: Ignition Coil Overheating?
my guess maybe too much power going to it?
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
11-20-2010, 05:59 AM | #3 |
Is this a factory HEI with the coil in the cap?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-20-2010, 06:28 AM | #4 |
if your not getting a full 12volts or you have a bad ground both can lead to overheating
11-20-2010, 04:51 PM | #5 |
What ground should I look for/clean? It is a factory style HEI.
11-20-2010, 06:21 PM | #6 |
some times there is a ground that is attached to one of the coil screws others have a ground strap under the coil that the coil sits on and is retained when the coil screws are tightened.
Fuzzy |
11-20-2010, 09:21 PM | #7 | |
CRM, Did you run a new wire for the HEI or did you use the existing wire from the old points setup? If you used the old wire there is resistance built into it. You need to run a new wire for the HEI. Where are you getting the coils from?
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 11-20-2010 at 09:28 PM. |
11-21-2010, 04:00 AM | #8 |
OhoneWS6 Thank you for the visual. Yes, that is all in good order. When I got the truck, it had the original points distributor and ceramic insulator. i replaced it with a 12 gauge wire. Ill check the connections on it.
11-21-2010, 01:54 PM | #9 |
I got my coil from Oreillys.
11-21-2010, 04:20 PM | #10 |
Oreillys usually has decent quality parts. I've had issues with a lot of Auto Zone stuff. Usually things like starters and alternators. I'd also check to make sure the alternator is not putting out too much voltage. Where did the distributor come from?
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 11-21-2010 at 04:20 PM. |
11-22-2010, 02:44 PM | #11 |
The distributor is an aftermarket one that I bought brand new 7 years ago. The altenator is about 1/12 years old.
