Old 11-20-2010, 08:36 AM   #1
ratrodmiller
ratrodmiller's Avatar
windshield wiper conversion
Does anyone know a cheap fix for the vaccum wiper unit?Something that works good in off any other vehichle? I know you can buy a new electric conversion kit. any ideas? thanks
ratrodmiller is offline   Reply With Quote
Old 11-20-2010, 11:48 AM   #2
RootBeer 6117
RootBeer 6117's Avatar
Re: windshield wiper conversion
Ratrod,
Thadius(sp?) has a conversion he did using a rear wiper motor from a s10 blazer,its a single speed. This week at school I had to fix my blower motor on my 95 k1500 Chevy it only had high speed, As I was setting there reading the wiring diagram a thought hit me.I "WONDER IF" a person was to use the same set up for 4 speeds on a blower and ran the wiper motor would it work? I did some research and found the interment wipers on most GMs use a higher resistor value than the resistors on the blower motors, BUT I would think the Blower would run at a higher amps than the wiper motor. I am taking apart a 97 caddy so I am going to do more research on this only problem I don't think I have a single speed wiper.It might work, it might go up in smoke, (which might be fun). I will let you all know unless some one else has already tried this.
RootBeer 6117 is offline   Reply With Quote
Old 11-20-2010, 09:28 PM   #3
big_b
i used the wiper set up off an MGB in my '49. they are cable drive and you can adjust them to fit in almost any thing. i even managed to make the wipers sweep away from each other like how these old trucks came from the factory. the hardest thing i had to do was make a mount to bolt the motor to. they are 12 volt.
big_b is offline   Reply With Quote
Old 11-21-2010, 02:20 AM   #4
OrrieG
OrrieG's Avatar
When I was in high school I drove my dads 49 pickup to the coast with a girl friend. On the way back the wiper motor puked. I rigged a coat hanger to the wiper arm that she pulled out the open window on the way back. Crude but got us home. Last date we ever had in that truck.
OrrieG is offline   Reply With Quote
