WTB: Small Block Ram Horns
Want to but 1 set of small block angled ram horn exhaust manifolds in very good usable condition. Will settle for 1 passenger side if that is all you have. My passenger side has a crack in it.
Ray 1971 Cheyenne LWB 1965 C-10 Short Fleetside 350/350 2010 Harley Davidson FLHTK Last edited by repeeler; 11-20-2010 at 12:13 PM. |
Re: WTB: Small Block Ram Horns
Ill get some pics tonite when i go to the shop if you want them $75
i could use a clean set as well for a 72 , thanks
Sounds good!
Ray 1971 Cheyenne LWB 1965 C-10 Short Fleetside 350/350 2010 Harley Davidson FLHTK |
![]() Join Date: Nov 2007
I think I may have some as well. They have rust but aren't bad. 2bikemen@wi.rr.com Matt
here is a new aftermarket set,been smooth ready to coated 50.00 + shipping
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears 70 nova 5.3,350 trans 80 z28 350,350,trans,bought new 03 cat. 06 gmc swb ext cab |
![]() Join Date: Feb 2005
I have 2 sets of angled but they both will need new studs. 30.00 a set plus ride HAVE STANDARD RUST SURFACE CAN SEND TEXT PIS ONLY
www.stevensparts.com they have them new. there in Ft. Worth TX
69 swb stepside, rebuild and upgrade in progress |
No they are drivers not polished standard brow color, one set has them the other set has a stud missing on each one. And matt. You can't buy them new for 30.00
They look good but I am wanting a set of angled dump.
I'll take a set as long as there are no cracks. My pass side is cracked
#13 |
![]() Join Date: Apr 2000
I have a set but one has a surface crack. The crack does not go all the way through. Nice studs. $15 + Shipping.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
#14 |
"Junkyard Dog"
![]() Join Date: Jan 2008
I have a pair of new aftermarket angle backs for 115.00 plus ups charges. Pics available if needed.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
#15 |
'11 Z71 '88 V-30 Crew Cab '87 V-10 '69 Camaro SS '52 M38 '46 Rat Rod Word of the wise should be sufficient! |
#16 |
I have a set just like the ones 1 pu70 posted but without the crack can send text pics need cell##
