Old 11-20-2010, 02:06 PM   #1
Fesser
Fesser's Avatar
Blazer fender on a SWB fleet?
I've been searching on here but haven't found what I'm looking for. I have a 72 SWB fleetside and a 72 Blazer parts truck. My fleetside's drivers bedside is mangled all around the taillight and part way to the fender opening. The blazer's fender is nearly perfect. Sooo, I started thinking, what if I cut the outer skin of the fleetside fender from the center of the wheelwell back and replaced it with the section from the balzer. I could also swap the blazer tank and filler assembly at the same time and solve two issues at once. I'm sure this has been done but I haven't found any links. Any reason to think it won't work?
Fesser is offline   Reply With Quote
Old 11-20-2010, 02:57 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Blazer fender on a SWB fleet?
As long as you're comfortable cutting and welding the sheet metal I say go for it.
--Josh
Old 11-20-2010, 05:32 PM   #3
cdowns
cdowns's Avatar
measure b4 cutting
Old 11-20-2010, 11:59 PM   #4
Fesser
Fesser's Avatar
Any braces or structures between the inner and outer bed walls that I want to look out for, or aim for?
Old 11-21-2010, 01:46 AM   #5
RED72blazer
urban fourwheelin
RED72blazer's Avatar
I'd sell that blazer quarter and buy a long bed to cut up. Blazer stuff doesn't grow on trees.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
