Old 11-20-2010, 07:08 PM   #1
Nomadjunkie
Nomadjunkie's Avatar
How to measure correct shock length
I am at the point where I need to select rear shocks on my 57 3100 but am not sure how to measure for correct length and have no old shocks to compare to. It is currently on axle stands but can be set on the wheels. Sitting on the stands it is 20" from bolt to bolt where they mount.
Nomadjunkie is offline   Reply With Quote
Old 11-20-2010, 08:25 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: How to measure correct shock length
We need a little more detail on your suspension
dwcsr is offline   Reply With Quote
Old 11-20-2010, 08:36 PM   #3
Nomadjunkie
it has leaf springs and shocks on a 9" rear end. I am not sure if more info is needed or not
Old 11-21-2010, 02:24 AM   #4
OrrieG
OrrieG's Avatar
I had the same question when I put new shocks on mine (non stock suspension with 4" lift). I went to the store and found some that had the right mounting configuration and matching bolt to bolt length when in the middle of the travel. Before I measured some trucks that were close so the counter guy had a place to start. This was at a local specialty 4wd place, not a run of the mill auto box store.
OrrieG is offline   Reply With Quote
