Old 11-20-2010, 08:56 PM   #1
akpackfan
Steering Wheel help needed
'71 C10. Here is a pic of the steering wheel currently in my truck. Can anyone tell me what I'm missing to get a horn cap put on it? I bought the truck like this and I don't know what brand of steering wheel it is or where to get parts to finish it off. The horn circuit works because when I touch the wire to the center nut the horn honks. Thanks for any help.
akpackfan is offline   Reply With Quote
Old 11-20-2010, 09:00 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Steering Wheel help needed
Looks like you are missing the horn cap is all. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 11-20-2010, 09:06 PM   #3
akpackfan
Wes, do you sell the horn cap? If not, do you know where I can get one or what brand of steering wheel this is?
Old 11-20-2010, 09:08 PM   #4
Classic Heartbeat
It looks to be a grant wheel to me. Sorry but we do not have them, but just about any parts store should have them. You can even order one with a Bowtie or GMC logo if you like. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 11-20-2010, 09:29 PM   #5
fast_dev
fast_dev's Avatar
you need the cap and the spring.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 11-20-2010, 09:31 PM   #6
Yep looks like the same wheel (by Grant) that I have to put in mine. Looks like just the cap and spring (as mentioned) are all you need.
Palf70Step is online now   Reply With Quote
Old 11-20-2010, 09:36 PM   #7
akpackfan
Ok I'll try to find those locally. One thing that I don't understand, however. When I touch the wire end to the small tab that looks like the wire should slide onto, the horn goes off. Is this normal? How do the cap and that tab interact?
Old 11-20-2010, 09:44 PM   #8
Classic Heartbeat
Try lifting the isolator away from the wheel. You may just be making contact without the cap and spring. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 11-20-2010, 09:45 PM   #9
swamp rat
swamp rat's Avatar
What happened is the same thing that has happened to me twice now, the horn cap does not stay on the fiber washer, it has 3 dimples in the cap sides that snap over the fiber washer, eventually the spring pushes the cap off of the fiber washer the horn goes off, in my case it happened twice in the middle of the night! so after 2 replacement kits i gave up and my horn has been dissasembled ever since, naturally this was before i had the internet and i no longer had the packaging so i just said to hell with it. EDIT: The last fiber washer warped really badly and had edge cracks where the dimples were pushed over.
From what i understand grant may have re-engineered the horn kits they sell now because of this, but i have not checked into it, replacement horn kits last time i checked were about $80 but they do not include the horn cap.
Search Grant on google and check there webpage for the cap, and possibly call them and you may be able to purchase the cap.
Good luck! Subscribed!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-21-2010, 02:35 AM   #10
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Grant still has the same setup, I put one in in April and it is exactly the same fiber disc. Mine hasn't given me any issues. $80 sounds a little excessive considering I got my wheel and install kit for about $75 at summit, and there were some that were even cheaper. Let us know how everything works out! Oh yeah as mentioned above all you need is spring and cap.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-21-2010, 02:47 AM   #11
swamp rat
swamp rat's Avatar
Ok i was pretty peved to see the price for the kit.. i am guessing that the price musta went down or was miss marked every time i looked cause they were pricy, now about $25.
Looks like O'rileys also has replacement horn buttons too.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
