"Tail Gate Best Seat In House"
![]() Join Date: Oct 2007
My 06 Silverado has started a rattle
Some where up front .. maybe in the steering ,,maybe something loose under the hood,, sounds like something loose and rattles from bumps ..
Are there any things from this year that is a known rattle problem .. Might have to take it in to a dealer as my shop is full of 72 truck and it's raining day and night here in Oregon.. just thought I would ask.. gp
When you learn a thing a day you store up smart. |
![]() Join Date: Aug 2010
Re: My 06 Silverado has started a rattle
My Dad has an 06 Sierra, and had a similar problem. The local garage did something to it (can't remember what it was) and it seemed to stop for a little while. But the noise came back, and one day I checked his air filter and noticed that the heat sheild on the exhaust manifold had come off- it rotted off around the bolts. I took it out and the front end noise was gone.
More then likely yours is a different problem, but you might as well pop the hood and check. Last edited by Shaun1162; 11-20-2010 at 10:11 PM. |
Sounds like it could be the intermediate steering shaft. They (GM) had some issues with these in that body style. They had a grease kit for them that hid the problem for a while and I believe they have something else to possibly solve the problem. It will make noise on bumps and when you make turns. Also check the front shock mounts as I have seen some come loose and rattle.
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
![]() Join Date: Jan 2003
This is the shaft that Maxxd07 mentioned. Like was stated before the GM kit only lubed the problem, didn't fix it. They do have a "revised" shaft that supposedly fixed it, cost is around $125. Dorman Products sells a "fixed" version also, that in the link at the begining.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec -Gibson Stainless Cat Back Swept Side -SS Wheels 2005 Honda CRF250R 2006 Honda CRF150F |
Phone's ringin Dude.
![]() Join Date: Mar 2007
I vote steering shaft as well
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
I agree with the others. Here is a great thread with some tricks to try before replacing the shaft. I did it on mine, and it solved my knocking problem.
http://67-72chevytrucks.com/vboard/s...d.php?t=425309 |
its the shaft.... BUT if you want to verify. remove the bolt under the hood betweed the upper shaft and lower shaft and stroke the upper I-shaft in and out about 5 times. Reassemble. It will stop rattling for about 15k miles.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
If you replace the shaft will that fix it? How much is the shaft if you want to replace it?
Thanks! |
