![]() Join Date: Jan 2009
thoughts on cut/heated springs
the front coils on my 70 project have been cut, and the rear have been heated to drop the truck.(PO done this) i will admit i like the stance it sits pretty low. im building this truck as a "shop truck" that i will drive on the weekends and to work some. my question is pros/cons on the drop "method"? i have personaly never owned a truck that has been dropped this way, and not sure what to expect. just looking for some advise so i can replace the springs now, instead of later after is all put back together. thanks for any input.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
More Cowbell....
Re: thoughts on cut/heated springs
The CUT springs aren't that big of a deal. Your issue is the "HEATED" ones. It isn't a question of "IF" they will snap, but "WHEN"??? Tons of people have done it (me included), but they aren't safe.
As soon as you can, you really need to change the rear ones. Just my $0.02
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
i have heated ones on my truck and its hard to drive/ride in it. cant wait to do it right this winter
I have a 67 C10 and the PO had heated and pancaked both front and back. I agree I liked the lowered stance but it was a terrible ride. I just picked up a 3/4 drop from CPP and ride height is the same but ride quality is not comparable. I think it only cost me $300 for springs and shocks. It was one of the first things I did to improve the drive. I couldn't be happier. Good luck!
heated dangerous and dumb
looks like some new springs in my future. thanks for the input guys
Junior Member
![]() Join Date: Mar 2007
keep the fronts & replace the rears
frontstreetcycle on Instagram |
Big Red - Now its a SWB!
If you want to replace them on a budget AND you don't plan on hauling much (I've heard anything over 500 pound and you'll be bottomed out) you can put in some jeep springs for about 4" of drop. I'm not sure on the specific year/model to use but tons of guys on here have done it and I'm sure they'll chime in.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
I was told that chevelle coils spring work good as well. I am thinking about finding some at a salvage yard for using on my 67 c10 lwb. I dont plan on ever using the truck to it full max load. Does anyone know if nova,caprice,impala,belair rear coils would work? Or did they have rear coils or did they have leaf springs? I want to do it right the first time and I have a ways to go until I do drop it and by then I may have enough just to buy the basic drop kit 3"/5" drop coils. Sorry not tryin to hijack your thread. I just see alot of lowering questions. But not sure about other car coils. maybe just better off doing it right and not guessing.
Grandpa in the rustmobile...
jeep springs wont haul anything much over 150lbs without bottoming out, i hauled an ATV this weekend, bottomed out
Jeep TJ late 90's is what mine came out of 4" drop or so
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#11 | |
Junior Member
aftermarket drop springs are not much better...
the boat guy
keep the fronts replace the rears, it's cheap and easy enough. If it hasn't been done put a sway bar on the front. Imho best bang for your buck truck project.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#13 |
mine had heated rears for over 8 years (maybe more) and never snapped. the ride was absolutely terrible tho. I also like the stance, but put stock springs back on it this summer and really like the smoother ride. wasn't expensive either. if you want the lower stance i've heard cutting the springs isn't bad. whatever you do don't heat it. there's tons of options dropping, especially if you want to convert to discs. I've never talked to anyone who has actually used the drop springs. let us know what you decide
1970 lwb hugger orange. 454 duel fuel cng and gasoline. 1990 Ford F-250 Lariat 2008 Mazda3 |
#14 |
67-72 parts collector,…
![]() Join Date: Nov 2002
What brand of springs are you refering to?
Most aftermarket drop springs work great. You need to combine them with drop shocks and a few other suspension components. Care to explain?
#15 | |
Tot Roddin'
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 11-22-2010 at 08:52 AM. |
#16 | |
![]() Join Date: Aug 2003
Call ECE www.earlyclassic.com 559.291.1611 and let them know what you got and what you want. They are the easiest folks to deal with when it comes to our suspensions. I bought my front and rears from them and the ride is fantastic. Not to mention that you're riding around on borrowed time with those "heated" coils. Seriously, you want your truck to look "right" and ride nice, then get those taken care of now. Remember: you can lead a Horse to water, just can't make him drink. You can lead a Man to knowledge, just can't make him think.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
