Old 11-21-2010, 02:48 PM   #1
dzbowtie
dzbowtie's Avatar
radiator repair?
the radiator in my 70 c10 with a v8 had the top water neck of the radiator broken off where the water hose connects. can this be repaired usually by a radiator shop or is this a lost cause?
dzbowtie is offline   Reply With Quote
Old 11-21-2010, 05:55 PM   #2
cdowns
cdowns's Avatar
Re: radiator repair?
most rad repair shops could do the repair// take it in have them look it over and get an estimate// b4 getting estimate know what a replacement costs
Old 11-21-2010, 08:01 PM   #3
72shortbed12
I had the same problem but mine was hanging on by an inch of solder. I took it to a local shop and they flushed it, pressure washed the outside, soldered the neck back on and pressure tested it for $20. I was impressed.
1972 K10 4wd Swb 350, 4 speed, 205 t-case Sold
1971 Cheyenne 2wd Lwb 350 4 speed Sold
1972 K5 blazer 4WD auto A/C
72shortbed12 is offline   Reply With Quote
Old 11-21-2010, 08:45 PM   #4
nasqar
Here kitty kitty kitty
The camaro in my pic had the upper neck broke also and I took it in and they fixed it, flushed, and the whole 9 yards and it was $50. I was very shocked that they could fix it but i have been very impressed. This was much cheaper than a good quality replacement. The repair only took a day to fix.
nasqar is offline   Reply With Quote
Old 11-25-2010, 04:10 PM   #5
dzbowtie
dzbowtie's Avatar
thanks for the advice. the wallet is glad to hear it also!
Old 11-26-2010, 05:31 PM   #6
nasqar
bowtie...are in in the military since you are from Clarksville?
Old 11-26-2010, 06:04 PM   #7
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Your guy's shops sound great! I had to take in the rad from my wife's 41 GMC it took them a week to do it and I think they charged like $60, all they did was flush and fix a few pinholes then throw some paint on.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
