Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 11-21-2010, 03:57 PM   #1
sjarrett71
sjarrett71's Avatar
Got Air Compressor ?'s Also
I just picked up a used air compressor that needs a little bit of work. I thought it was going to need a new pump because it was locked up but it appears it will just need a new connecting rod and the crank polished. Gonna be into it A LOT cheaper than buying a new one (even if I do have to buy a complete pump). The stats on it are 5hp/60 gallon;
SCFM
11.4 @ 40psi
9.0 @ 90psi
125psi Max
It's just for my home garage but will it be able to handle pretty much everything I need it to do? Basically just air tools, maybe a paint sprayer, a DA sander, and stuff like that?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 11-22-2010, 07:51 PM   #2
red69ss
Burnouts are therapeutic
red69ss's Avatar
Re: Got Air Compressor ?'s Also
http://67-72chevytrucks.com/vboard/s...d.php?t=423600 Here you go in post 12 I linked a couple of charts on sears and northern tool that list air requirements for common air tools.
That compressor will likely run a DA, but it's going to work the comp. pretty hard. If you can get it running cheap though I would do that and see if it meets your needs, if not you can sell it and upgrade later.
1969 CHEVELLE SS
1972 C10 ALMOST DAILY DRIVER
1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE)
1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR)
"My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield
"The difference between genius and stupidity is that genius has its limits." - Einstein
red69ss is offline   Reply With Quote
Old 11-22-2010, 08:35 PM   #3
sjarrett71
sjarrett71's Avatar
Thanks for the info.
-Scott-
