Old 11-21-2010, 06:22 PM   #1
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
3* down angle on Power booster/Master cylinder?
Does this look normal...or did I somehow get the wrong bracket or something?
New CPP power booster/MC/prop valve combo...mounts up with 4* down angle (title is wrong)....which 1* is coming from the truck...other 3* from the bracket. I'm used to seeing these setups lower in the back... then in the front.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-21-2010, 08:27 PM   #2
raycow
Re: 3* down angle on Power booster/Master cylinder?
Does the booster line up with the pushrod hole in the firewall? If not, could you have the bracket inverted?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-21-2010, 09:26 PM   #3
68GMCCustom
this came as a complete assembly from CPP just as shown. The bracket has 5 holes....the 4 main plus it uses 1 of the steering column bolts....no way it could be upside down.
Kurt -
Old 11-22-2010, 01:35 PM   #4
Mike J
vw guy & now c-10 guy
Mike J's Avatar
yeah, that looks weird. I have that same set-up on my truck and im pretty sure it's mounted straight up and down- no lean...
'68 long fleet
Finally made some progress on the build!!!
My Build Thread
Mike J is offline   Reply With Quote
Old 11-22-2010, 11:06 PM   #5
tonypaul
tonypaul's Avatar
Did you ask CCP about it? It does look a little off, it still looks great- but off a little. I got my bracket from a Fiero, its shorter than the stock ones but its level.... Things that make you go "HUM"
tonypaul is offline   Reply With Quote
Old 11-23-2010, 12:13 AM   #6
68GMCCustom
if you look at the bracket where it meets the booster....the top is out further then the bottom. Most brackets I've seen where the other way around...tho this one cannot be inverted.
Sent Jeff a PM with the pic...we'll see what he comes back with.
Kurt -
Old 11-23-2010, 12:38 AM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
mine is a stock one and it looks the same way I have scatched my head over it a million times too??? but it works fine and since its the oly way it will bolt to the stock bolts I figured it was just onew of those dumb things
might be a pic in my build
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 11-23-2010, 02:49 PM   #8
Transformula
Transformula's Avatar
Yes that is normal. Mine is the same, stock. It has to do with the linkage behind it.
Transformula is offline   Reply With Quote
Old 11-28-2010, 02:27 AM   #9
Captainfab
60-66 Nut
I agree. That is a stock '67-'72 booster assembly. They obviously work fine, but I just don't like the look, or the distance out from the firewall. That is why I make the booster brackets that I sell.
Old 11-28-2010, 03:06 PM   #10
68GMCCustom
you have a different bracket? I understand the reason for the booster position is to clear the hood? Do you have any pics of this bracket? ....or even installed?
edit---found in your sig....but understand I'd have to also buy a new booster? and m/c or no?
Kurt -
