converting from wide 5 to 4 3/4 disc
Right now my truck is wide 5 disc front brakes but I got a line on a really nice 10 bolt disc rear that is 5 x 4 3/4 bolt pattern and was wondering how hard it is to convert the front to 5 x 4 3/4 bolt pattern?
I thought i read it depends on the width of the disc brake rotor. I did some searching but I can't find any information on this swap. So, if any of you know what is needed that would be great. I would post some pics of my front disc setup but it is in another town right now getting body work/paint. I am hoping it is as simple as buying the 5 x 4 3/4 rotors from Autozone and putting them on. Thanks in advance for any replies and once I get the truck back from paint I will post some pics. I am going suede black (not flat) on the body, camaro gold on the top and inside of cab, black carpet/seat/gauges and suede black on the door inserts.
Lotus Current Rides/Projects 1955.5 Chevy shortbed truck 1952 Chevy Coupe Deluxe car |
Senior Enthusiast
Re: converting from wide 5 to 4 3/4 disc
Here’s a thread that suggests it will work, but is short on details:
http://67-72chevytrucks.com/vboard/s...=camaro+brakes And post #5 on this post shows a rotor that has been redrilled: http://67-72chevytrucks.com/vboard/s...=camaro+brakes I cannot find information where anyone has actually swapped just a rotor to obtain the 4 ¾” bolt pattern. I you find something please post a link, as I’m sure there are others interested in that information. If you have to replace major components like spindles to obtain the passenger car bolt pattern, the savings on the rear axle may not be worth it. However if it’s safe to redrill the rotor it might be. Whether the pattern on your existing rotors can be changed will probably depend on what they look like from the backside. Some I’ve seen have a lot of webbing around the lug studs and would require machining away a lot of material to get a flat spot for the new stud locations. |
It's Better With Nitro
I think someone posted a list of part numbers, etc. for front rotors and corresponding bearings on this forum.
I don't know if this is an option for you, but I already had my rotors when I wanted to go to a 5 on 4.75 pattern many years ago (I had a set of vintage wheels I wanted to run at the time), and it was a lot less expensive for me to machine my existing rotors from a 5 on 5 to a 5 on 4.75 pattern. ![]()
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes Last edited by vin63; 11-22-2010 at 01:19 PM. |
#4 | |
Maybe these, but before you lay down your money you might want to find out what calipers they work with.
http://www.performanceonline.com/DIS...10-TRUCK-5514/ The guy in http://67-72chevytrucks.com/vboard/s...=camaro+brakes who said Quote:
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. Last edited by raycow; 11-22-2010 at 02:49 PM. |
Senior Enthusiast
Thanks for sharing the link. In spite of several years of random web searches, I've never found anything helpful about putting passenger car wheels on a truck - besides redrilling.
60-66 Nut
![]() ![]() Join Date: Mar 2007
There was a thread here somewhere where a guys stated that a certain year Impala rotor would fit the truck spindle, and has the 4.75 bolt pattern. But I never was able to confirm what he was saying. I'll see if I can find that thread.
#7 | |
You would stand a better chance of finding a C3 Corvette rotor, which I know is still reproed. Same bearings, but those used a 4 piston caliper, so once again, the caliper fit is an unknown. Also, you know what Corvette parts prices are like. Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
Airport Bum
One of my club mates clipped his '59 Elco with a Caprice that was 5on5.
His rear was 4.75, so he researched a Z-28 hub/rotor that swapped. May work here, I don't know.
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
Senior Enthusiast
I just stumbled on this link while searching for something else. It's the kit instructions for installing Chevelle rotors on 60-66 series trucks:
http://www.classicperform.com/Instru...DF/6062DBK.pdf |
