Old 11-22-2010, 01:04 PM   #1
Piece of Work
Cultural Infidel
Piece of Work's Avatar
Question power steering pulley removal
How do you remove the power steering pulley? I need to change to a 2 groove and can't get the old one off.
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 11-22-2010, 01:25 PM   #2
cdowns
cdowns's Avatar
Re: power steering pulley removal
you need a special tool to remove ps pulleys sears and most autoparts stores heve them pretty cheap
i'm sure you can find at a good swapmeet too
Old 11-22-2010, 01:30 PM   #3
Piece of Work
Cultural Infidel
I'm starting to feel like a "special tool"!
Thank you, I'll get one this evening.
posted via La-Z-Boy
-Mark
Old 11-22-2010, 03:33 PM   #4
ls1nova71
ls1nova71's Avatar
On newer power steering pumps you need a puller/installer, because the pulley is a press fit on the shaft, but on every 67-72 I've seen, the pulley has a nut holding it on and the shaft has a woodruff key in it. Are you not able to get the nut loose? Once the nut is off they will just pull off by hand.
ls1nova71 is offline   Reply With Quote
Old 11-22-2010, 03:35 PM   #5
Piece of Work
Cultural Infidel
the nut is off. pulley won't come off, even with persuasion.
posted via La-Z-Boy
-Mark
Old 11-22-2010, 03:49 PM   #6
ls1nova71
ls1nova71's Avatar
It must be rusted/seized on then, because it's not a press fit. But I just double checked a pump I have in the garage and it does have the lip on the center of the pulley that the puller pulls on, I didn't think the older ones did, so a power steering pulley puller should work to pull it off.
