Add sending unit to existing tanks?
I've been working on my 69 LWB for a while now and I think it's about ready for the road. Only thing concerning me is the fuel tanks, the PO installed 2 tanks (custom built i think) with the fill caps are in each wheel well. The gas gauge doesn't work for either tank, is it possible to add a sending unit to these? Also considering replacing with something else as the caps on these tanks are hard to get on and leak if not screwed on all the way.
Craig Posted via Mobile Device |
Re: Add sending unit to existing tanks?
I guess it depends on what the tanks are. There are universal sending units that you can put in a tank as long as you gave a flat area to screw it to. Make sure you get a 0-90ohm unit to work with our gages. Here is one source.
http://www.sw-performance.com/products/SDRFuelSdr |
Thanks for the link, that might be just what in need. When i get home from holiday travel I'll see if I can find a way to mount it.
