Old 11-22-2010, 05:03 PM   #1
charv712
drop member parts list
Hey Guys. I would like to put together a parts and price list together for purchasing a "drop member" as well as necessary parts like airbags, compressor, everything else.
I would like to eventually drop the front and then the rear, and just want to know what kinda money I need to get together in order to do this!
Also, what airbags should I get, where do I go to purchase these? Thank you guys for your time
I'm thinking I'll need
drop-member
tubular arms
charv712 is offline   Reply With Quote
Old 11-22-2010, 06:20 PM   #2
jimmydean
jimmydean's Avatar
Re: drop member parts list
I would run Slam Specialties RE7 bags up front, you can get those from Nate, too. You will also need a rack and associated steering parts as well like the u joints for the steering shaft.
Nate is supposed to call me and go over the list this week (I hope). I am going to use a manual rack for ease of use, I am also running stock arms and spindles because I won't be using a huge tire/wheel combo (about 28" tire diameter).
As far as compressor and management, that is all up to you. You can go manual fill low budget or all the way up to something like the eLevel systems that have presets and auto adjust. Just depends on what you want and how much money you want to throw at it.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 11-23-2010, 02:56 AM   #3
jimmydean
jimmydean's Avatar
All that is needed is the dropmember kit, rack, steering shaft, and bags. You can also use tubular arms and drop spindles if you want to get WAY down.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 11-23-2010, 08:37 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Might consider the SS7's as they don't balloon out as much... not that there's anything wrong with the RE7's.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
