parking brake not working
Title says it all. I just had my new trailing arms put on, the parking brake hooked up on both sides, but they don't work. I got under the truck, noticed there was a lot of play in the lines, tightened it up as far as I could, but they still don't work. When I press the parking brake pedal, I don't feel any force until I'm about halfway down, then it gets tight as it should. Having taken out the play underneath the truck, is there any place else I can tighten it up to get the ebrake working again?
thanks in advance!
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy" 1996 Gmc 1500 Z71, 350, 4l60e, 3.73s 1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s 1989 Toyota Pickup 22re, auto, 3.73 |
Re: parking brake not working
Did the cable come loose from the hooks? Just in front of the rearend connection there is a hook on either side to pull the cable over to the frame. If that's come loose you could have slack in the cable.
Restoration Virgin!
did you use the original parking cables from the truck???....There are LWB and SWB parking cables.....Also, i think I read somewhere that you need to depress the Pbrake about halfway down and then hook up the cables from under the truck....make sense?
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
Old Skool Club
![]() Join Date: Jun 2001
www.inlinetube.com has replacement brake cables, stainless or OEM-style.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. Last edited by ChevLoRay; 11-23-2010 at 02:54 PM. |
Check inside the cab behind the parking brake mechanism. My cable housing was not secured so pushing the pedal would only pull the housing without pulling the cable. I fastened the housing to the firewall and my parking brake worked great afterwards.
