Old 11-22-2010, 07:55 PM   #1
lkefthrlkeson
cummins or 6.0 lq4 which one is better?
Been noticing a lot of lq4 and cummins swaps on here. Just wondering which one has the most advantages as far as gas mileage, power, etc.. Do they cost about the same to do? Can you use a 4l80e with a cummins? Gonna get used a lot for my spray business, so I want it to be able to hold up either way. Thanks for the replies....
lkefthrlkeson is offline   Reply With Quote
Old 11-22-2010, 09:37 PM   #2
b454rat
Re: cummins or 6.0 lq4 which one is better?
LQ4 needs a computer to run, early Cummins don't. That right there is a major selling point for me. LQ4 is crazy expensive to buy, I'm getting 3 $1800 or so.
If you have the adapter you can bolt up a 4l80, but will need a stand alone computer to shift it, or go manual valve body.
I'm a diehard Gm guy, but can't beat a Cummins.....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-22-2010, 10:20 PM   #3
lkefthrlkeson
[QUOTE=b454rat;4308660]LQ4 needs a computer to run, early Cummins don't. That right there is a major selling point for me. LQ4 is crazy expensive to buy, I'm getting 3 $1800 or so.
I'm a diehard Gm guy, but can't beat a Cummins.....[QUOTE]
I saw that you were planning on doing a cummins swap here pretty soon. Just a couple of questions... How much does a good used cummins cost? Where is a good place to get a deal on one? What all is involved in swaping from gas to diesel etc...?
Old 11-22-2010, 11:26 PM   #4
camshaftgsxr
camshaftgsxr's Avatar
if its a two wheel drive lq4/9 all the way, if its a 4x4 do the cummins
the ls series engines arent that hard to swap in as long as you use a stand alone harness or a camaro harness, the truck and suv harnesses have an anti theft feature i havent figured out yet..
camshaftgsxr is offline   Reply With Quote
Old 11-23-2010, 10:44 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
They all have the anti theft feature in the PCM/ECM ( not the harness)after I think 2000/2, it just needs to be programed out, pretty easy for a tuner or someone with the software available.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-23-2010, 11:15 AM   #6
camshaftgsxr
thanks clyde, my girlfreinds dad has a 6.0 swapped 64 panel wagon, asked him after i posted and he told me,
Old 11-23-2010, 12:23 PM   #7
jitteryguy
GoatLube Experss
jitteryguy's Avatar
why do you say 2 wheel drive LQ4 ? I'm want'n to put the 12V Cummin's in my 2 wheel drive dually, is there width issues ? the only ones I've seen were in 4X4's , I noticed they notch'd the frame for the AC. is this the issue ?
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 11-23-2010, 05:54 PM   #8
camshaftgsxr
well i would put a cummins in your dually too i meant in a 2 wheel drive short bed single cab (the smaller trucks)
<< like that one
Old 11-24-2010, 10:22 AM   #9
lkefthrlkeson
thanks for all the replies guys... I think I'm gonna go with the lq4/4l80. Good power, decent mileage, and they're good for at least 200k miles. Hopefully, I can find a low mileage one for a good price.
Old 11-24-2010, 10:42 AM   #10
Clyde65
Clyde65's Avatar
I have had pretty good luck with LKQ here in North Texas, you might want to give them a call.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-24-2010, 06:40 PM   #11
496 BB
496 BB's Avatar
Search here for the engine. http://car-part.com/
a LQ4/9 WILL NOT even come close to TQ outputs of a Cummins. Mileage will also be better in Cummins. Cost is where the Cummins comes into play. That and if you want an automatic you will need to have one built that was made to go behind a cummins unless you want to spend lots of money fabbing up something else. You can always get a NV4500 5 speed to go behind them also but need a better clutch than stock if you plan on putting some power out...which you will once you drive it. I have a good friend who is finishing up putting an Allison behind a Cummins in a 99 Silverado. Its been a PITA to say the least. Cummins is alot more expensive than going gasser.
LQ4/9 on other hand is what Im planning on doing next year. These motors are excellent motors for building power reliably. Stock bottom ends will hold more than you will likely throw at it. Throw a nice spec'ed cam and set of heads and your sitting pretty. Just a cam will net around 60 hp if tuned right. You DO NOT need to go fuel injection with this setup either. You can carb it also as both Edelbrock and MSD have kits to convert and still retain stock coil packs with preset ignition curves. Look here.... http://www.jegs.com/p/Edelbrock/Edel...55239/10002/-1 The best thing is with the LQ4/9 you can keep the TH400 trans if you want with minor changes. You can also use stock harness if going FI and build your own. OR you can goto multiple places and have them custom make you one but are usually around $400-$600+ to get.
Another option you have is getting what I got in my HD which is an 8.1L (496ci) motor and mate it to an Allison or a TH400. Trust me with the tuning I got on here its nuts. You have not driven one of these until you get an EFI Live tune and no TM anywhere. I am in between the two motors and leaning towards the LQ4 for gas mileage since I plow in winter and mud in summers with it.
496 BB is offline   Reply With Quote
Old 11-24-2010, 08:29 PM   #12
draggin86
draggin86's Avatar
umm LQ9 by far its a modern motor getting you better MPG and HP..
draggin86 is offline   Reply With Quote
Old 11-24-2010, 08:30 PM   #13
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I wouldn't even mess with a gas engine for a tow vehicle, or a hauler if I was considering doing a cummins swap. Reliable, fuel efficient, and cheap power, 12v that is. What more do you need?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-24-2010, 08:31 PM   #14
Dieselwrencher
In a dually? I think not. I'd put my dinosaur 12v up against a LQ9 in a heavy truck any day. Then go hook up the trailer and go run some hills.
Ryan
Old 11-25-2010, 12:37 AM   #15
clinebarger
A 6BT Cummins with a P7100 injection pump will have better milage, more power potential, & last alot longer.
As far as using a 4L80E behind a Cummins...I whould not recommend it, as strong as they are it whould not last, They may handle 1000hp but it cant handle 750 ft lbs at 1400 RPM. A 47RE or a 48RE Dodge can be built stronger.
clinebarger is offline   Reply With Quote
Old 11-25-2010, 09:36 AM   #16
b454rat
I thought the lq4 was the Duramax??
For any type of towing I wouldn't use a gasser. I never owned a diesel, towed a lot with gasser's , but like already said, can't beat a Cummins for power, upgrading, economy, durability, etc.
I'm getting a Cummins that is rated at 175 horse. Doesn't sound like a lot, but torque is 450-ish. Get a #100 fuel plate, those numbers go to 250-ish horse and 620 ft/lb of torque. For about $200.
http://www.puredieselpower.com/catal...ate-p-451.html
Old 11-25-2010, 10:13 AM   #17
D.FENS
You're saying the truck will get used for your business, right? The diesel would be better for towing and / or hauling, but you gotta think it through in terms of how long it'll take to get enough use out of the truck to recoup the investment.
The buy-in on the diesel swap is a little cheaper, but most people who do Cummins swaps don't leave them stock ($$$) and the transmission / drivetrain mods to support 1000 - 1500 ft/lbs of torque ain't free either.
I'm eying up an LSx swap for my dually, because the only towing I do is a tow dolly or 20' single-car trailer, and seldom haul anything heavy (still think sometimes I bought too much truck for my needs but too late now).
D.FENS is offline   Reply With Quote
Old 11-25-2010, 10:55 AM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Another thing to factor in is fuel costs. Around here diesel fuel is still much higher than gas. Besides, who wants to fuel up at those stinking diesel pumps.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-25-2010, 11:33 AM   #19
lkefthrlkeson
Yes it will get used alot during spray season. I have a 300 gallon spray rig that will get mounted in the bed of the truck(much easier to maneuver down lease roads than hauling a trailer). That's really the biggest it will carrying. Hope that gives a better idea of what it'll be used for.
Old 11-25-2010, 11:43 AM   #20
496 BB
496 BB's Avatar
Duramax is either codes LB7 (01-04.5), LLY (04.5-06), LBZ (06-07.5), LMM (07.5-2010), and new one is LML. LB7 was non emissions BS motor and non variable vain turbo.
If your getting a 6BT Cummins complete and running for $200 thats a HELLUVA a deal.
Provided the better mileage you get in a diesel you will still be saving money even paying slightly more in fuel.
Old 11-25-2010, 11:47 AM   #21
496 BB
496 BB's Avatar
So you figure a gallon of water weighs about 8 lbs. Just for ****s and giggles lets say so does your spray. 8x300 gallons=2400lbs. Thats NOTHING. You can go either way and be totally fine in towing that. Even if it was 4000lbs I wouldnt be worried about the motor....springs and lack of air bags yes but not motor.
I would go whichever route is the easiest to afford and put the money you would be saving back into your business. Trust me when I say you will need the capital.
Old 11-25-2010, 12:35 PM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by 496 BB View Post
...Provided the better mileage you get in a diesel you will still be saving money even paying slightly more in fuel.
Not from what I have been told by several diesel truck owners. It will depend on the price in your region, but here in South Texas you will pay a LOT more for fuel.
Articles-
"Refining Sierra"
Old 11-25-2010, 12:50 PM   #23
joe231
joe231's Avatar
up here in the middle of Oklahoma diesel is @ 50 cents more a gallon.....
what are some real world MPG numbers for the 6BT? And the LQ4? I know a few guys with newer crew cab 4x4 3/4 ton trucks with the LQ4 stock, they are lucky to Get 14MPG. I also know a guy with a 2001 dodge SRW 1 ton extra cab long bed, with a tune getting 20+MPG.
I'm not familiar with what year Cummins are what, but to compare those 2 numbers, the LQ4 with gas @ $2.50 a gallon is 18 cents per mile cost verses the Cummins fuel at $3.00 a gallon is 15 cents per mile....I'm not sure if this is a apples to apples comparison, and the wear and tear parts replacement for the Cummins are probably going to be more expensive also.
CHEVY ONLY
Old 11-25-2010, 01:04 PM   #24
0331grunt
Now what??
0331grunt's Avatar
I have a stock '06 1 ton Ram MegaCab with Cummins, 6speed manual, and 4x4. I pull 12-15k lbs regularly and still average 13+ mpg. When not towing, I get 19-22 easy. I only have a 4" straight pipe and intake as the only upgrades and I have 325hp/600tq. Will be getting a programmer soon. I would go with a Cummins in a heart beat, regardless of price of fuel. just my $.02..
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 11-25-2010, 02:15 PM   #25
lkefthrlkeson
First off, thanks for all the replies so far.
So what are people doing about the transmission in a cummins swap? Definitely want an automatic. What are most people paying for a good used cummins engine?
