Old 11-22-2010, 08:07 PM   #1
scum1
scum1's Avatar
botched bed cut
the po of the truck i bought mentioned to me that it was a long bed originally that had been cut down to short bed, and a short box put on it. so naturally when i drove from vegas to la...... i forgot to check it out. until now. long story short. they made a vertical cut in the frame combined the pieces and rewelded. thats it. no reinforcement on the outerframe side. but on the inside they "reinforced" it with a thin piece of steel that is runnin along the frame edges. it doesnt even touch where the weld was. it pretty much made a box tube frame in that area. get it? i tried to snap some shots but i couldnt get under there and was in a rush. ill throw em up anyway. but what the hell do i do with that. just reinforce the hell out of it??
scum1 is offline   Reply With Quote
Old 11-22-2010, 08:21 PM   #2
scum1
scum1's Avatar
Re: botched bed cut
this is flipped sideways. its a vertical cut and weld..
Old 11-22-2010, 08:22 PM   #3
scum1
scum1's Avatar
Re: botched bed cut
this is on the inside of the frame rails but its such a bad pic i cant even tell what it is of, and i just took it.
Old 11-22-2010, 08:25 PM   #4
scum1
scum1's Avatar
Re: botched bed cut
Originally Posted by lakeroadster View Post
Like you said, get us some photos and we can help evaluate what's needed.
Does the bed fit square and does the truck track true down the road?
If everything is square and true more than likely some grinding and then additional reinforcement plates should be good enough, but hard to say without seeing it.
the bed is missing bolts everwhere so it wobbles around, i only drove it to the u haul place to tow it. and it drove good, for bouncin on the front coils, but it really didnt drive that bad at all. no pulling to any side. im just amazed that it held up that much. it looks so weak.
Old 11-22-2010, 08:43 PM   #5
scum1
scum1's Avatar
Re: botched bed cut
outside frame rail
inside frame rail
another
another
under frame rail
Old 11-22-2010, 09:16 PM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: botched bed cut
Try a regular camera, not a cell phone. Its still kinda hard to see.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-22-2010, 09:26 PM   #7
Bugeyev8
Bugeyev8's Avatar
Re: botched bed cut
wow..even with the bad pics I can see that is some really ****ty welding, I would grind it all down and then crank the welder up and burn a good bead over the crappy one , then grind and add a fish plate across the inside, before doing that make sure the thing is straight and correct
or the way I would do it is get another rear frame section and cut it on a bias and do it right, should be easy to get a rear frame section
I would not trust that with my life as it is
Its just metal..it can be repaired
Good Luck !!
Bugeyev8 is offline   Reply With Quote
Old 11-22-2010, 09:36 PM   #8
scum1
scum1's Avatar
Re: botched bed cut
Good Luck !!
i agree with the not trusting my life...i think i might do your first suggestion and try and "re-do" it. cuz i would rather not cut my frame off, not by myself at least. but well see. as far as making it straight. just level and take some measurements around the frame?
Old 11-22-2010, 10:59 PM   #9
rbar
rbar's Avatar
Re: botched bed cut
I might just find another shortbed frame, but a plate on the inside is probably a must. I prefer a Z cut on the frame, but a little late now.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 11-23-2010, 02:20 AM   #10
scum1
scum1's Avatar
Re: botched bed cut
anyone have anything else to comment in..my plan now is to pull the bed take a closer look. get rid of that plate and reinforce both sides with some nice steel plates. anyone absolutley object?? this is a mild daily driver...
Old 11-23-2010, 09:24 AM   #11
erock805
erock805's Avatar
Re: botched bed cut
you got some good advice. pull bed grind out some of the junk, check for cracks, reweld and fish plate it.
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 11-23-2010, 11:32 AM   #12
scum1
scum1's Avatar
Re: botched bed cut
lakeroadster, nice info im definetly going to be doing that. thanks for the help. ill be starting this as soon as i can and let you know how it goes
Old 11-23-2010, 12:01 PM   #13
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: botched bed cut
nice post lake..
and I agree with the others, fish plating, and general reinforcing will do the trick.
Old 11-23-2010, 07:36 PM   #14
jocko
jocko's Avatar
Re: botched bed cut
Some additional information on fishplating the frame (a guy had a similar problem on a welding website) - not necessarily anything new on the first page, but if you select page 2, it does address recommended fish plate thickness, etc. Personally, in addition to the fishplating, I would have some holes drilled in the plate so as to have some holes to do some spot welds on also. http://www.millerwelds.com/resources...sh-Plate-Welds
By the way - for any of you expert welders - since this is a repair of something scum inherited - i.e. there's no Z, do you recommend plating both sides - or maybe all 3 internal sides (include top/bottom insides??) Just a thought. The fact that it's not Z'ed would bug me til the cows came home...
Old 01-13-2011, 11:13 PM   #15
scum1
scum1's Avatar
Re: botched bed cut
hey guys still working on this problem with my frame..been busy..but i jsut came across this on cpp's site..anyone know exactly what these were designed for..to box your channeled frame?? does it go on the inside of the existing rails or the outside? cuz i was thinkin i could cut out the plate on it now, make a fish plate out of it to weld on the inside of my frame rail, then add this section from cpp to reinforce it further...any info would help me out. thanks
http://www.classicperform.com/Store/...ck/6372RFS.htm
Old 01-14-2011, 12:04 AM   #16
SCOTI
SCOTI's Avatar
Re: botched bed cut
Those peices are made to fit inside the frame rails.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
