Easy way to get the inside handles off?
like, the door handles and window cranks? i know there is a pin that lets them go but i cant
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
Re: Easy way to get the inside handles off?
pushed mine out with a small screw driver.
Cruzin
there is a tool you can get pretty cheap at the parts store, or i have heard people take a rag and pull i through or around it to catch the clip and make it come out
tool...
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Active Member
![]() Join Date: Jul 2007
I use a spring hook tool to grab the clip and pull it. To reinstall, I put the clip on the handle and put a little dab of grease on the door piece. I place the handle on and give it a sharp tap and it will pop back in.
Here's a tool similar to the one I use. ![]() |
