Scum1's 63
1963 chevy c10. was a lwb cut down and has a short box on it. 350 out of a 76 chevy along with the control arms discs and spindles etc. no crossmember though. power steering, decent interior and dash. lookin to drop it a little and get all the original gauges workin and interior lookin good. then drive drive drive!
ill get some better pics once i get started. but heres a few ![]() ![]() ![]() ![]() ![]() |
1961 crewcab
Re: Scum1's 63
nice.
I like the long bed cut down to a short, the wheelwells are bigger, which looks better to me when they are slammed. dash looks nice -uncut radio+guages!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Re: Scum1's 63
1961 crewcab
Re: Scum1's 63
Re: Scum1's 63
i had no idea about the difference in fenders..thats interesting. i have been busy with school lately but im done here in a few days and ill be home to work on it..ill throw up some pics as i get into it!!
Re: Scum1's 63
some recent pics
Re: Scum1's 63
asd
Re: Scum1's 63
so i got the dash ready to go back in. all fluids are changed. got the headlights/turn signals/brake lights all wired. made my shock mounts for the relocation, ready to drop in my c notch, and waitin for some new shocks and parts in the mail. after that, the front end and finally fix that frame hackjob.
Re: Scum1's 63
i love the 60 63 dashes the 64 66 looks nasty! with the rectangle speedometer ,will a 60 63 fit in a 64 66 dash?
Re: Scum1's 63
so the notch is all done..started tearin the front end apart ready to rebuild ball joints/bushings etc..
Re: Scum1's 63
i got a couple questions though..in this first pic you can see quite a bit of shims in the upper control arm, is that normal? was that done for alignment purposes and should i reinstall them?
second pic- you can see that there is a bolt missing in the uca mount to the frame. it is the same on the other side. the hole doesnt match up anyway, should i loosen the others up and maybe drill it out and put a bolt thru? |
#12 | |
Re: Scum1's 63
#13 |
Re: Scum1's 63
thanks for the quick response scoti. i jsut reposted this in the suspension section so i suspect i will hear more of the same.
#14 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Scum1's 63
That missing bolt is where the one hole needs to be drilled when switching the suspension crossmembers. Apparently whoever installed that crossmember was being lazy. It appears that you have a '71-'72 front suspension and crossmember.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 02-04-2011 at 01:48 AM. |
#15 |
Re: Scum1's 63
oh $%^..i was told that the x member was pulled from a 73+
what caught your eye as to the 71-72 specific year. edit: ah steel bushings vs rubber. im an idiot. well i re ordered some parts turns out lower ball joints, adjusting sleeves and idler arm will fit both 71-72 and 73-87. so i need new upper bj and tie rods. <hand on forehead> oh well Last edited by scum1; 02-04-2011 at 02:33 PM. |
#16 |
60-66 Nut
Re: Scum1's 63
The dust shields behind the rotors is another indication of the year of the suspension. The '71-'72's are different than the '73-'87's.
You might want to double check on those lower ball joints. I'm pretty sure the '71-'72 lower's are different than the '73-'87's. I believe the uppers are the same though. Edit: looks like I had that backwards. The lower ball joints are the same. It is the uppers that are different. Sorry.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 02-05-2011 at 03:08 AM. |
#17 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Scum1's 63
I never knew the dust shields were different.
Captainfab,... do you have any pics of the differences?
#18 |
60-66 Nut
Re: Scum1's 63
I'll see if I can get a couple pics and post them.
#19 |
Re: Scum1's 63
well its been a while since i updated this ill throw some pics up to show whats been goin on...
made an adjustable trackbar from my old tie rods..and a bracket to the trailing arm |
#20 |
Re: Scum1's 63
ground off the bumpstop bracket and steering stop..and a stance shot. not the most recent but pretty close. its a lil lower now..
#21 |
Re: Scum1's 63
heres a shot of my recent parts gathering..new headers, some drop coils (that i might end up selling now), some whitewalls off clist, and some steelies!! headers are on, should be mounting the wheels tomorrow and getting it aligned.
#22 |
Re: Scum1's 63
recent
#23 |
Just here to tinker
![]() Join Date: Jun 2008
Re: Scum1's 63
THat's great man! I like the wide whites and the stance for sure. Looking good.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
#24 |
Re: Scum1's 63
thanks corts60, but i actually threw on some new tires, skinny whites haha ill throw up some pics as well as some of my new task, my 700r4...
heres a link to a specific thread for the 700r4, http://67-72chevytrucks.com/vboard/s...=1#post4813760, where i have recieved alot of info,, if anyones interested.. i also picked up a 63 grille needs blasted but pretty straight and im redoing the wood bed, raising it up an inch or two..like i said ill throw up some pics in a bit.. |
#25 |
Re: Scum1's 63
heres some pics of the finished bed...i really like how it turned out..did it all myself for under $200.
