Old 11-22-2010, 10:59 PM   #1
k5hart
k5hart's Avatar
Defroster Divertor box repair
During my never ending heater core replacement project I realized that the flap in my divertor box was cracked. This is a common problem with our trucks and will cause the air to not redirect out of the defrosters. I wondered why my defroster sucked! Anyway, a few people suggested that epoxying the door was a possible solution but some didn't think the repair would last. That got me thinking about what would last. Something that would add support on top of re-attaching things together. Here's my fix.
I took a piece of flat steel bar I had around and cut it to size. I put a small angle on one long side so it would slip under the rubber piece that surrounds the door. You will have to take a razor blade and cut one nub out of the rubber in the middle of the flap so the metal will slip under. I painted the top so it was clean and left the glued side raw steel.
Then I used a 3M adhesive made for attaching emblems. It sets up somewhat rubber like but very solid and is strong as heck. It takes a day or so to set. As you can tell I used a lot, coated the bottom and put a bead around the steel.
I haven't put this in use yet but I've done two different boxes and tested (played) with it a lot and so far no problems. Just thought I would share my idea and see what ya'll thought.
2006 Silverado CCSB, 1939 Ford Sedan, 1962 BelAir Wagon, 1976 Vega Panel
Charleston, South Carolina
k5hart is offline   Reply With Quote
Old 11-24-2010, 12:30 PM   #2
aintmisbehavinn
Re: Defroster Divertor box repair
Excellent idea, I'm on my second with the same problem again. I thought about plastic, a scraper from Home Depot paint department milled down with a grinder. This is exactly my thought when I rip it out again...Good job.
aintmisbehavinn is offline   Reply With Quote
Old 11-24-2010, 03:36 PM   #3
k5hart
k5hart's Avatar
Thanks! I hope it lasts. I think it will. I will post back here if it fails. I don't think it's necessary to use such a thick piece of steel like I did. I just had it laying around the shop. I think it would work, maybe better, with something thinner. Hope it works for you.
