Old 11-23-2010, 10:52 AM   #1
66farmer
66farmer's Avatar
66 rear mount gas tank
It's time to order a gas tank, the two tanks that I'm looking at are 49-52 chevy passenger car which Lakeroadster showed how to install it and did a great job of it (THANK YOU). The other is a 60ish Ford Falcon, has any one installed this tank and could share some info and pictures. I'm looking at the pros and cons between the two tanks. I plain on the filler neck in the bed.
66farmer is offline   Reply With Quote
Old 11-23-2010, 01:49 PM   #2
badriand
badriand's Avatar
Re: 66 rear mount gas tank
lmc and classic offer kits that fits under bed and have hookups to work with original sending unit.
badriand is offline   Reply With Quote
Old 11-23-2010, 03:20 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Post #4 on the following thread shows a Falcon tank mounted:
http://67-72chevytrucks.com/vboard/s...ht=falcon+tank
Old 11-23-2010, 04:45 PM   #4
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Check out my project JO JO in the build section you can see a tank from Performance online. Extremely nice kit. early frames are wider than your , I know many use the 70's blazer tank that you can get for under 80 bucks. Good luck
GMR-PERFORMANCE is offline   Reply With Quote
Old 11-23-2010, 08:31 PM   #5
66farmer
66farmer's Avatar
That's what I like about this site you ask a question and you get great feedback thank you. Mr Roadster using the tank that you did who hard do you think it would be to move the fill tube to the center of the bed.
Thanks for your help
Old 11-23-2010, 08:49 PM   #6
SFTorange
SFTorange's Avatar
I bought my tank from Dave Boyd. See the thread from the 67-72 forum. I bought the 67-72 version for my 1966 C-20, and it fit great after I moved one of my rear crossmembers back about an inch and removed the spare tire crossmember. If you don't want to make any modifications, he will make you a tank exactly to your specs. I felt that his pricing was great too.
http://67-72chevytrucks.com/vboard/s...d.php?t=362307
SFTorange is offline   Reply With Quote
Old 11-24-2010, 08:37 PM   #7
66farmer
66farmer's Avatar
John I have one more question. Can you get your hand up in the frame to get to the bed mount bolt I see in your picture that your's is standing up like you welded a nut on the bottom.
Keith
Old 11-25-2010, 02:05 PM   #8
andyh1956
i just measured the tank we took out of son n law's '69 mustang. it measures 24.5" x 32.75" & is 8" tall. it would fit perfect between the rails & has a rear center fill wit 2.25" in dia. looks like a perfect bed fill tank. you would need a mustang sender & have it re-calibrated for our fuel gauge. i will post piks tonight. we bought the new one at "mustangs r us" or something like that for $99.
andy
andyh1956 is offline   Reply With Quote
Old 11-25-2010, 02:23 PM   #9
Rich 5150 69
Rich 5150 69's Avatar
There is a thread in here on Mustang and Falcon tanks use, the issue was they were only 16 gallons, they bolt down right onto the frame rails, now I`m hearing they have increased the volume as an option also...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-26-2010, 12:18 PM   #10
andyh1956
ok here are the piks of the '69 mustang tank. i found them on ebay from $68 to over $200. and from 16 gal to 20. take yur pik!
andy
Old 11-26-2010, 09:20 PM   #11
66farmer
66farmer's Avatar
So has anyone installed a f-----d gas tank and if so how did it turn out.
Old 11-26-2010, 09:40 PM   #12
Rich 5150 69
There was a guy that installed a 69/70 cougar tank in the rear of a `59 chevy pu, frames are the same width in the rear, he had to trim 1.5 inches off each side lower rail to fit....
Old 11-27-2010, 12:15 AM   #13
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
John-
For the Chev tank, did you have to modify the braces on the bed, or raise the floor at all? My bed is off the truck, and in the back yard. I'm starting to forget what it looks like.
I like the 49-54 Chev idea, and I believe Tanks is only about an hour away from me.
And while I'm at it, has anyone here seen an F body tank in one of these? I have heard of it, just never seen pics. I wouldn't mind using a stock tank and stock GM fuel pump.
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 11-27-2010, 10:31 AM   #14
66farmer
66farmer's Avatar
John
How much above the frame did you mount the tank. That F body tank does not work for me. It looks like I'm going to use the same tank that you did just wanted to look at the ford falcon tank first.
Keith
Old 11-27-2010, 10:42 AM   #15
Rich 5150 69
Here`s a shot of the couger / mustang tank install, and yes he trimed 1.5 inches off each side of the lower frame rail.
Old 11-27-2010, 11:15 AM   #16
Rich 5150 69
[IMG][/IMG]
and another
Tapered back, rear fill, all the fuel and vent are in the front, I`ve thought about it just have to trim too much from the rails.
He said it never leaks....
Old 11-27-2010, 11:21 AM   #17
66farmer
66farmer's Avatar
Thanks John NICE drawing
Old 11-27-2010, 12:01 PM   #18
Rich 5150 69
Originally Posted by lakeroadster View Post
You're welcome!
One other note in reference to the Mustang/Cougar tank installation photos above. The truck in the photos has leaf springs. It doesn't have a track bar and the cross member is different from that used on 64-66 frames. On our trucks (63-66) the track bar crossmember is mounted at an angle (see drawings I posted above).
I know leaf springs were used on 4x4's but looing at the photos the truck isn't a 4x4? Perhaps this truck isn't a 63-66?
I only bring this up because I am curious, as tight a fit as this tank appears to be, if the Mustang/Cougar tank will actually fit in a shortbed coil sprung track bar configuration frame?
I`m sorry John this was a `57 chevy pu, the frame measurements are the same and you`re right its leaf sprung, it was mainly for Andyh1956 review to show what he was getting into, it might fit, but I think there are better choices out there. By the way its also 21 gallon..
Old 11-28-2010, 03:02 AM   #19
tapeworm
tapeworm's Avatar
Thanks for the info guys! I know this question has been beat to death, but there are so many options for indecisive people like me!
I was going to take the easy blazer tank route, but plans of changed. I will need to run an electric pump, and prefer to use an intake setup.
