Old 11-23-2010, 01:54 PM   #1
gloriavoxdei
gloriavoxdei's Avatar
door alignment issues
When I bought my K30 the PO had replaced all 4 doors with doors from a Suburban. Unfortunately he did not align them very well. My question is does anyone know of a way to align the front doors without having to pull the front fenders?
1978 GMC Jimmy, 400, th350, np203 with part time conversion, Fibrecraft popup camper, soon to get a 14 bolt/d44 swap
2001 Yukon XL2500, 6.0, 4L85E, 4x4, family truckster
gloriavoxdei is offline   Reply With Quote
Old 11-23-2010, 02:49 PM   #2
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: door alignment issues
what year?
typically ou take yoru time with a friend and patiently shim. tighten, close the door and repeat.
make syr he replaced the door pins.. some people r mega cheap a**es
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 11-23-2010, 03:48 PM   #3
xs-style
xs-style's Avatar
Steck door alignment tool. Pick one up at o rielys for about 30 bucks.
1978 Scottsdale - celebrating 10 years of teaching me profanity
1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold
1987 k5 blazer - sold... :\ seed money for the 81
1981 k20 4x4 - 5.3 swap in progress
Events attended:
Spring GOG 2011
Dale JR car show Summer 2012
Gathering at Tommys pickup parts
xs-style is offline   Reply With Quote
Old 11-23-2010, 05:45 PM   #4
burger
I used an offset box wrench to adjust my door hinge alignment. I am not sure that I am using the correct terminology for the wrench... it's the type typically used for the distributor hold down bolt. Took a little bit of patience and cursing, but it got the job done. FWIW, I own a Steck door alignment tool, and I find it near worthless. All you need to do is slightly loosen the hinge bolts, push or tug on the door in the direction you need to go, tighten the bolts back up, check, adjust, check, adjust, check, adjust, check.
burger is offline   Reply With Quote
Old 11-24-2010, 07:17 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
there's a tool for that?
i always thought trial and error ,trial and error and trial and error
curse and curse and curse
course just get someone to drive into the side of it (like me)and you won't worry bout the fit
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
