11-23-2010, 04:04 PM | #1 |
Glovebox leak
My '70 normally sits on an uphill angle in my driveway, but when I park on the street or a level parking lot, my glovebox fills with water during moderate to heavy rain. It seems to trickle in on the far right hand side. The windshield seal looks to be good. Before I start tearing things apart, where is the most likely source for the leak ?
1970 C10 LWB with SB 307 & TH350 |
11-23-2010, 05:07 PM | #2 |
White wall terror
Re: Glovebox leak
My 71 does the same thing so I will be looking forward to reading some replies on this one.
11-23-2010, 05:13 PM | #3 |
Re: Glovebox leak
There could be a little hole in the cowl. Mine does that too...Took my cowl off and found little pinholes from rain sitting in there over the years it rusted through. It sux! One of next summers many projects...
11-23-2010, 05:17 PM | #4 |
Re: Glovebox leak
if the sealant in the raingutters is dried out and cracked and shrunk rain can leak down inside the roof and down the door pillars
11-23-2010, 05:21 PM | #5 |
Re: Glovebox leak
This is what i suggest, and bear with me, this is gonna be a little long winded of an explanation. there is a seam in the inner cowl right above and behind the glove box. to access this seam you will need to remove the cowl panel. its not a real big deal. there are 2 bolts under the hood and 2 bolts in the upper door jamb area. also about 8 or 10 phillips head screws holding the cowl on. also you will have 2 remove the wiper arms. once you get the cowl off look down in the opening on that side of the inner cowl. you will see a seam that is sealed with old seam sealer. remove as much of the old seam sealer as you can , and reseal. also if you look in the rain gutter on the back of the firewall ( the area where the engine wiring goes up to the top of the firewall.) you will see a seam that runs the whole width of the cab. if you will check for cracks in the sealer and rust holes and seal it up, you will most likely have solved the problem. those 2 seams usually are the culprit of leaks into the glove box. there are other seams that can cause leaks into the cab as well as the windshield itself but these are the most prevalet on glove box leaks.
i survived cancer and kidney stones, but my kids are killing me. |
11-23-2010, 05:40 PM | #6 |
Re: Glovebox leak
Subscribed!!!!
I have also had the dredded glove box lake. it allways depended on if i parked facing in or backing into the driveway, facing in would make the lake in the box. this is probably the root cause of my floor rotting. So far i have resealed the drip rail and also because i beleve my Windshield to have a bad seal, water on the dash, i tryed a bit of silicone around the seal in the upper surface areas of the bottom corner as a temp fix. I have yet to try to reseal the seam Under the cowl but plan to.. But in the mean time i keep the rat under a car cover.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-23-2010, 05:59 PM | #7 |
The Older Generation
Re: Glovebox leak
I can tell you how it is getting into the glove box. There is a seam on the right side of the glove box liner and the overlap where it is put together is situated so that any water that drips on top of the liner and runs down the side runs right into the glove box...(whew, that was a long one) I put some sealer along that seam so the glove box won't fill up until I can fix the leak permanently. LockDoc
11-23-2010, 07:05 PM | #8 |
Cultural Infidel
Re: Glovebox leak
I had the same problem, all of the above is correct. As an added measure, I sprayed the glove box with rattle can bedliner.
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold! It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
11-23-2010, 10:39 PM | #9 |
Cruzin
Re: Glovebox leak
i might have to look into this myself.......
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
11-24-2010, 12:54 AM | #10 |
Re: Glovebox leak
But, if it still leaks then the water is passing thru the carpet to the floorboard.. but at least the registration and other stuff is safe huh??
11-24-2010, 01:03 AM | #11 | |
Re: Glovebox leak
LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-24-2010 at 01:04 AM. |
11-24-2010, 01:09 AM | #12 | |
Re: Glovebox leak
I had a rubber mat and the water would creep under it and the moisture would be trapped there, it was amazing how much damage happened in 10 years.. from then on its allways under cover yet still waiting for rust repair.
11-24-2010, 02:05 PM | #13 |
Re: Glovebox leak
Wow! I had no idea how common this problem is!
I guess I know what I'm doing this weekend...
1970 C10 LWB with SB 307 & TH350 Last edited by dadsgreentruck; 11-24-2010 at 02:06 PM. |
11-24-2010, 02:23 PM | #14 |
Re: Glovebox leak
notice how it hasnt occured in a 67 or 68 onlyin 71 and 72s funny i know what could fix this problem making a metal glove box in sert and have it welded painted properly and your done
11-24-2010, 02:25 PM | #15 |
Re: Glovebox leak
maybe thats why most of the owners manuals are always gone they get soaked full of water and thrown away
11-24-2010, 05:08 PM | #16 |
Re: Glovebox leak
Interesting thread.
Mine is a 70 and during wet weather the base of the dash fills up with water. Never the glove box. If your sitting on the seat and run your hand along the base of the dash theres a lip - it gets water in it and drips onto the floor below the steering column. Ive never been able to trace it back to anywhere so I can only assume it comes from the drip rail above the windshield. Good thing its now -20. no more liquid. |
11-24-2010, 09:14 PM | #17 |
Who's got steelies?
Re: Glovebox leak
I've had this problem in the burb and my truck with the 67 cab. the 70 cab didn't leak. On both it was from leaves in the cowl rusting it out. On the truck, I cleaned it up around the seams and used rtv to seal them back up. I then put bug screen on the backside of the cowl grill to keep the stuff from getting back in. Haven't done the burb yet, but on both, I'd bet ya that the rust damage around the kick panel/hinge pillar to floor area was caused by the leaks in the cowl.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
11-24-2010, 09:21 PM | #18 | |
Re: Glovebox leak
I have also had the water build up on the bottom base of the dash panel too, but totally forgot about that, my guess that its from the drip rail too.
