Old 11-23-2010, 05:22 PM   #1
RED-85-Z51
Found some rust..
I knew I wasnt that lucky...to get a truck that just had minor cab corner rot.
I slid under the pass. side today to hack off the mangled exhaust and found a peice of the rocker panel is gone, and the rust got up into the floor pan a couple inches. Looks like the vent window in that door is bad and has been leaking for some time...
I think, given the size of the problem, and the place it is in, I can get away with cutting out the section, tacking in a new one, and fiberglassing it top and bottom, then rhino line the floor of the cab.
RED-85-Z51 is offline   Reply With Quote
Old 11-23-2010, 05:54 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Found some rust..
It happens. Glad you have a plan of attack. Good rule of thumb is if you can see visible rust, assume it is worse where you can't see.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-24-2010, 07:11 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
lol try living up here
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
