11-23-2010, 05:30 PM | #1 |
Anyone have a Rear Panel template?
I need to make the rear panels for my Jimmy and I was hoping someone had a template I could use? I will pay for shipping...
Much appreciated, Travis |
11-23-2010, 11:15 PM | #2 |
Re: Anyone have a Rear Panel template?
Save your money and just get some cardboard, a box cutter and a sharpie and make your own template. Should take you 30 minutes tops.
11-24-2010, 09:42 AM | #3 |
Its lookin' like a Blazer!
Measure the length and height, cut that out of whatever wood your using (I used 3/8" plywood.). Place the cut piece of plywood in the bed against the wheel well. Make sure you have it sitting in the right spot front to back, even between the front and rear posts. With the wood against the wheel well take a pencil, lay it on the wheel well and trace it out on the wood. Cut it out with a jig saw and you have your panel. You may have to notch the bottom corners but its no big deal. Just remember measure 2-20 times, cut once. You can see mine here, start with post #820.
http://67-72chevytrucks.com/vboard/s...264226&page=33 |
11-24-2010, 12:39 PM | #4 |
good advice guys, thanks. That sounds a lot easier than I expected.
