11-23-2010, 08:40 PM | #1 |
need power steering help
I am trying to put power steering in my 68 K-10. I have done a ton of work The motor is installed and now i am looking to be able to mount the pump to the motor it is a small block with headers can anyone help with what i need for a bracket for the pump??? Thank you
11-24-2010, 01:42 AM | #2 |
Re: need power steering help
Check the parts thread for people selling truck parts would be a good start.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-24-2010, 11:23 AM | #3 |
I have used several different pumps from 68-78.
69 stepside, 1/2ton, 4X4, 350/350/205 |
11-24-2010, 12:32 PM | #4 |
The Older Generation
You should be able to use any small block PS pump bracket from the same era as your motor. The only thing you need to watch is whether you have a long or short water pump. LockDoc
11-24-2010, 12:50 PM | #5 |
Between Trucks...
I used a bracket made by Alan Grove. Mines 2WD, don't know if there would be a difference with 4WD.
Beat it to fit, Paint it to match... |
11-24-2010, 01:37 PM | #6 |
member #16
You need this setup for short pump.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
11-24-2010, 05:45 PM | #7 |
Thanx for the help John and others John that is exactly the set-up I am looking for
11-24-2010, 11:01 PM | #8 |
And it's a "B" to put on with the radiator in!
