Old 11-23-2010, 11:33 PM   #1
64c10stepside
Power steering pump 64 230 inline 6
I'm puting power steering on the 64. It has a 230 inline 6. Will a set of brackets for a 75 and up 250 6 cylinder work to mount the pump?
Thanks...
64c10stepside is offline   Reply With Quote
Old 11-24-2010, 12:09 AM   #2
tkeduk8r
tkeduk8r's Avatar
Re: Power steering pump 64 230 inline 6
yup... but the 73-up used a long water pump that would require you to use the 250's pulleys too.....
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 11-24-2010, 12:16 AM   #3
geezer#99
geezer#99's Avatar
If the donor brackets are from an integral head motor they won't fit.
Old 11-24-2010, 12:37 AM   #4
andyh1956
i just did what you want to do on a early 250 i put in a m715 jeep. i used the later brackets, water pump & pulleys but like geezer says the brackets don't fit. i cut them up & left the pump bracket on the pump but fabbed a new bracket from the head to reach the pump bracket & welded them together. i will take a pik for you & post it tomorrow.
andy
andyh1956 is offline   Reply With Quote
Old 11-24-2010, 07:38 PM   #5
raycow
If you are having trouble finding brackets, look at 6 cylinder cars. PS was more common on those than on the trucks. As already mentioned, stay away from the integral heads.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-26-2010, 12:43 PM   #6
andyh1956
ok here are the piks of what i did. you can see i cut the mount in two, then bolted a piece of flat to the head then bridged the gap. i run the adjusting arm from the alternator mount below. ain't fell off yet!
andy
Old 11-26-2010, 12:59 PM   #7
raycow
Andy, that's not a bad setup at all.
Ray
Old 11-26-2010, 05:10 PM   #8
andyh1956
it's worked good 'cept for one problem. i may have to re-mount the steering gear upside down. every time i fill the pump reservoir all the oil runs out the bottom of the gear!
