Old 11-24-2010, 04:23 PM   #1
johntom
johntom's Avatar
Truck won't start!
My 71 has no power to the ignition. I turn the key to acc and there is no power to my radio. When I turn the key to start it, the brake light in the insrument panel goes on, but there is no juice. Bettery is fine, I thought it was the ignition switch and got a new one. Still nothing.
Can you guys help please?
68 short fleet cst
71 custom deluxe lwb RIP (parts truck now)
71 Datsun 510
49 GMC 150 (waiting for me for the past 15 years)
johntom is offline   Reply With Quote
Old 11-24-2010, 08:42 PM   #2
raycow
Re: Truck won't start!
Did this problem start all by itself, or did it occur only after you did some kind of work on the truck?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-24-2010, 08:46 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
Just a few suggestions I have found that works. I replaced the positive and negative cables on my '71 and made sure the connection points were clean and shiny. The ground wire goes directly to the engine.
Doing this fixed the intermittent problem with the engine turning over and starting.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-24-2010, 10:48 PM   #4
57larry
I'd check the neg. battery cable 1st (ground)
57larry is offline   Reply With Quote
Old 11-26-2010, 10:57 AM   #5
johntom
johntom's Avatar
It ended up being my starter solenoid. There was also a ground issue for the dash that needed to be tightened.
Thanks for your help gentlemen. I appreciate it
68 short fleet cst
71 Datsun 510
Old 11-26-2010, 11:22 AM   #6
Shyguy
Junior Member
Shyguy's Avatar
Thank you for letting us know you got it fixed. Electrical problems can sure be difficult.
