Old 03-04-2003, 09:33 PM   #1
Demon of Dreams
WEEE!!!
Double Hump Crossmember Help ~ I confused.
I was at a boneyard today and was looking for the double hump....
however... I don't know what the hell I'm looking for.
Basically I have a few different options.
One: Crossmember with no lateral bars.
Two: Crossmember with lateral bars.
Now... even the crossmembers that have the lateral bars are different... some have a lot of holes, some only have a few.
Some have 2 mounts and some have 1...
the one I had them set aside for me later measures 33.5 tip to tip at the laterals, and 33 even tip to tip on the main crossmember piece, and 5.5" from bottom of crossmember to the highest point of the lateral bar...
I've got a 350/TH350 2WD ...
what exactly am I looking for to do this??
Demon of Dreams is offline   Reply With Quote
Old 03-04-2003, 10:10 PM   #2
AirMale
AirMale's Avatar
Welcome to my nightmare..... I went through 3-4 double humps until I found one that worked for me. The most important thing for me was that the transmission stayed the same height. There are a few crossembers that will raise it 1-2 inches higher and that's no good. I also wanted to use the braces on both sides to keep the frame stiff. One thing's for sure, you'll know how to get a crossmember in and out in record time by the time you find the right one.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 03-04-2003, 10:15 PM   #3
Demon of Dreams
WEEE!!!
doh
well... at the moment, i don't know what to do...
I would like to have the laterals on there, but I'm not running a lot of power or anything...
there are single mount and double mount crossmembers... then there are 4wd and 2wd ...
I am so confused
Old 03-04-2003, 11:00 PM   #4
1FaastC10
1FaastC10's Avatar
stick with a 2wd. what exactly are these "laterals" that you're talking about?
1FaastC10 is offline   Reply With Quote
Old 03-04-2003, 11:03 PM   #5
Demon of Dreams
WEEE!!!
I don't know which is which for the 2WD or not... thats my whole problem...
the laterals i'm talking about are the two support pieces that come off and arch upwards off the main crossmember to keep the frame from twisting n whatnot, added support
Old 03-05-2003, 01:14 PM   #6
PHOENIX
I pulled thi crossmember off of a 2wd suburban in a junk yard. Tom currently has my crossmemeber, but he is supposed to be giving it back soon Anyway heres a link with a few pictures of the crossmember:
http://67-72chevytrucks.com/vboard/s...ht=Crossmember
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 03-05-2003, 01:56 PM   #7
Demon of Dreams
WEEE!!!
looks good to me...
what about the two side bars? are they all that important? doesn't look like that one has any
Old 03-05-2003, 03:39 PM   #8
PHOENIX
I dont know if I want to give this away or sell it now. Im planning a tranny swap, someday. I may need this. But if you contact the guy in the link he should be able to get you some of those extra braces. I dont remember the sub. having the braces, but I know what your talking about. I believe the crossmember was just bolted onto the frame without any additional bracing.
Old 03-05-2003, 03:56 PM   #9
Demon of Dreams
WEEE!!!
the one with the braces at the yard they want $75 for :ugh: scary thought that is...
I'm not really worried about the braces if they're not that important...
but any idea if I have the double mount or single mount currently? I've yet to check and can't really do much about it at the moment...
Old 03-05-2003, 05:23 PM   #10
AirMale
AirMale's Avatar
I disagree, the braces are there for a reason. If you ever decide to put a radical motor in your truck you will want the frame to be as stiff as poss. Just my opinion
86 SWB 9.0 LITER
Old 03-05-2003, 05:25 PM   #11
Demon of Dreams
WEEE!!!
well... I just want to make sure i'm getting the right thing if I do indeed shell out $75 for the damn thing... lol ...
Old 03-05-2003, 06:34 PM   #12
PHOENIX
Never said anything about not needing the braces, what I said was the vehicle which I pulled that crossmember off did not have the braces. I would also like to add, that it didnt look like it ever had them either. But if it were me, I would add them, atleast on one side.
Old 03-05-2003, 06:50 PM   #13
Demon of Dreams
WEEE!!!
hehe well, some of the ones i saw don't have them, which is why i'm a bit confused...
Old 03-05-2003, 07:07 PM   #14
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I am sure you are addressing the braces when you say "laterals"
Like this:
http://www.captkaoscustoms.com/images/framecross3.jpg
I ran mine without them (PITA to put back in under the truck) for about 5 years with a 454 and 4 speed that I wasn't featherfoot with. It is there to make the chassis laterally stiffer, and I put them back in as you can tell in the pic. Typically you can look under a 73-75 and 1/2T with any engine config and it will have one.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-05-2003, 07:09 PM   #15
Demon of Dreams
WEEE!!!
that looks about right...
dumb question though...
how the hell would I go about putting that in with a tranny and body in the way? :rofl: doesn't look all that easy
Old 03-05-2003, 07:26 PM   #16
AirMale
AirMale's Avatar
Great pic! I used a lift and a tranny jack and had no problems. If your on your back in the driveway-->forget it!
86 SWB 9.0 LITER
Old 03-05-2003, 08:01 PM   #17
Demon of Dreams
WEEE!!!
lmao... crap... well I could use a normal jack and jack stands but I really doubt it...
Old 03-06-2003, 12:27 AM   #18
Captkaos
Captkaos's Avatar
It isn't that hard to put back in if you don't have exhaust running in the way, but it is still a PITA.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 03-06-2003, 02:18 AM   #19
Demon of Dreams
WEEE!!!
well, I was going to be pulling it off and putting the new one on before i put my exhaust on
man sometimes i wonder why in the hell I ever buy chevy's because they involve so much work to get what I want done...
Then I remind myself... its way easier than working on import trucks or a ford or dodge ... LMAO....
Would I be safe for awhile to not use the lateral support bars if I just want to get it done quick and easy and keep the lateral supports for later when I do need to replace some body parts? cause in all honesty one of these days in the future I'll have to replace the cab and fenders anyway
in your honest opinion guys, would I be safe? I'm running nothing more than a mild 350 and i don't drive all that hard too often...
Old 03-06-2003, 10:38 AM   #20
Captkaos
Captkaos's Avatar
Like I said, I ran mine for 5 years that way. I was street racing it if that makes you feel any better.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 03-06-2003, 02:36 PM   #21
Demon of Dreams
WEEE!!!
i think i may have to go for it without them then... thanks guys
