Old 11-24-2010, 05:36 PM   #1
JGross
V8 350 small block experts Help
The 350 came with my 65 C10 so I did not put it together. I pulled the plugs and spun the motor over and got water out of #8 cylinder. So I'm thinking blown head gasket even though the PO said it was running fine and only had 5,000 miles on a rebuild. I pulled the intake and this is what I found.
It appears that the water came in through the carb and sat on top of the intake valve until I spun the motor over. However I noticed that the water jacket port was blocked off and the intake manifold, an Edelbrock 2101, did not have a matching port is this normal? Question 2, the small fitting on the right, is this the connection for the oil pressure gauge?
JGross is offline   Reply With Quote
Old 11-24-2010, 06:01 PM   #2
duallyjams
duallyjams's Avatar
Re: V8 350 small block experts Help
2) is the oil pressure
on smblk only on the front on the intake water flows the back does not.
did you do a compression test before you pulled the intake to make sure the head gasket was ok ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-24-2010, 06:14 PM   #3
Greg63
Enjoy your truck
Greg63's Avatar
Looking at your picture, it is possible that coolant passed by the intake gasket at the rear coolant port and migrated along the head until it got to the #8 intake port. The silicone at the bottom of the head under the coolant port probably prevented the coolant from getting into the lifter valley.
Greg
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 11-24-2010, 09:57 PM   #4
rideblue00
rideblue00's Avatar
I agree w/Greg63. The intake on 8 there looks a little orange/crusty.
rideblue00 is offline   Reply With Quote
Old 11-25-2010, 01:41 AM   #5
Captainfab
60-66 Nut
Wow, someone got a bit carried away with the high temp silicone. That's completely unnecessary. Well hopefully you are correct in the sequence of events. Hopefully the water didn't make it into the cylinder and sit there for a while. If it just sat in the intake port and rusted away, then you may have to pull that head and have it rebuilt to restore the seal of that intake valve. But if you're pulling one head, you may as well pull the other and have it freshened up too. That's a shame someone let that happen. That looks like a fairly clean engine.
