Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-24-2010, 06:35 PM   #1
Alex Hayley
T350 shift points
I have a 406 (~500 hp), a T350 (2800 stall) and a 3.73 posi. After installing the engine and rebuilt transmission, I noticed that transmission would shift very early, at about 2000 rpm, unless I get on it. I have what I believe to be an adjustable modulator...it has a screw in the vacuum nipple. Is there a rule of thumb of where to set your shift points with a stall higher than stock?
Alex Hayley is offline   Reply With Quote
Old 11-24-2010, 07:08 PM   #2
man-a-fre
Re: T350 shift points
screw the screw in the modulator clockwise (in) to raise shift points,or recalibrate the governor.
man-a-fre is offline   Reply With Quote
Old 11-24-2010, 08:28 PM   #3
Alex Hayley
Right but where should I set the shift points with a 2800 stall? Should I set the shift point slightly above the stall speed (3200 for example at 1/2 throttle)? Or is there some other way of determining the proper shift points?
Old 11-26-2010, 01:00 PM   #4
Alex Hayley
ttt
Old 11-26-2010, 01:18 PM   #5
rjs53
I don't think there is a set point, I think you'll have adjust it to your liking
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
