Old 11-24-2010, 08:14 PM   #1
WHITE-NOISE
WHITE-NOISE's Avatar
14 bolt rear in a 68 ???'s
well im basically doing a frame up build on my 68 4x4 longbed, first i started with a nice set of torches and got rid of the eaton rearend and the cheezy old worn out leaf springs and the death trap closed knuckle dana 44! swapping a 60 front and 14 bolt disked rear and 1 ton 56" rear springs from an 85 military truck......well i got the springs hung and axle center back where it should be but it never dawned on me that the 68 frames are skinnier than the 80's body chevys and i have to move my spring pearches....
my question is does anyone know how much i need to the perches in...i know theres alot of people that have done this swap and im hoping someone might know the measurements, i already got rid of the old rearend or i would just measure it off that.
WHITE-NOISE is offline   Reply With Quote
Old 11-24-2010, 08:45 PM   #2
Mike C
Mike C's Avatar
Re: 14 bolt rear in a 68 ???'s
Early 4x4 should be 40" spring centers. 2x4 is 42.5" center. The '73 and up one ton trucks are also 40" spring centers FWIW.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-24-2010, 10:49 PM   #3
msgross
msgross's Avatar
Just install your springs, center the axle and measure for the new perches.... 68 had longer rear springs than 69 and up too...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-26-2010, 10:14 AM   #4
duallyjams
duallyjams's Avatar
I have a 64,69 and 87 the frame width is the same on all of them.GM used different spring frame mounts on different years hence the perch width is different.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-26-2010, 05:40 PM   #5
WHITE-NOISE
hmmmm, yea that would make sense! i have a set of 80's frame mounts i may throw them on and see how that works!
