Old 11-25-2010, 12:04 AM   #1
ah_5500
Truck is always dead?
The problem I'm having is that something keeps draining the battery. After it sits for a day-ish it's dead, won't hit a lick. Battery checks out good so no dead cell or anything. I'm not leaving anything on so I'm lost and out of options. I was wondering if maybe there's something on these ol beasts thats bad about causing this problem. Thanks for any help.
ah_5500 is offline   Reply With Quote
Old 11-25-2010, 12:10 AM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Truck is always dead?
When it is dark, disconnect the battery cable. When you re-connect it, there should be no arcing. If it throws a spark, something is drawing current. At this point, you might want to remove fuses, one at a time. Each time, you can reconnect the cable to see if it sparks. When it does, you know what's drawing current.
Member Nr. 2770
Old 11-25-2010, 12:27 AM   #3
ah_5500
Even though checking with a test light the fuses don't seem to be drawing current? I have been disconnecting the + to keep it from dieing and noticed tonight that it did arc when I hook up the one little wire that goes to it. The wire comes off the bat and goes into a block thing that has a wire that goes into passenger side firewall and another that goes into the harness that goes across radiator support. Thanks
Old 11-25-2010, 12:35 AM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Unhook the cable at the battery terminal and put your test light between the battery and cable. If you have any drain it will glow, then start removing the fuzes to isolate the drain.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-25-2010, 12:46 AM   #5
ah_5500
Also after doing some searching I've rounded up some possibilities and questions. I receltly did some motor work, top end, and one thing I did was installed a hei dis. Is there any thing I need to do to the voltage regulator or or starter because of the points to HEI swap? The voltage reg is a yearish old and the starter few months. Thanks again
Old 11-25-2010, 01:00 AM   #6
sleepertruck72
sleepertruck72's Avatar
The starter should not be affected by the HEI swap, I dont think the voltage regulator would either. How did you wire your HEI ?
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 11-25-2010, 01:05 AM   #7
llowlife
Alternator diodes can drain a battery when they go bad....Try disconnecting the alt for the night. There are tests but this is the easiest.
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot.
I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace...
72 short step w/ 388 /4l80e/ and 3.08 gears.
llowlife is offline   Reply With Quote
Old 11-25-2010, 01:12 AM   #8
ah_5500
I wired the hei with the stock hot wire for the points. And, disconnect the alt to what extent? The 2 wire plug and both wires that are screwed on? Also, I just did what s/t said and it did light up but other powered stuff did to?
Old 11-25-2010, 01:47 AM   #9
67ChevyRedneck
67ChevyRedneck's Avatar
You shouldn't use that wire. It only has 8 or 9 volts going to it, the HEI needs a full 12. Most people run a wire from the fuse block to the HEI. Just make sure that it only has power in the run position.
Check this out...
http://67-72chevytrucks.com/vboard/s...ad.php?t=17403
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-25-2010, 01:54 AM   #10
Youngbuck7072
Youngbuck7072's Avatar
i had the same problem with mine, make sure the negative cable is tightly hooked onto the block or frame
........................ __
............._______|__\____
............|_({})______({})]
................(O)..........(O)
Youngbuck7072 is offline   Reply With Quote
Old 11-25-2010, 02:15 AM   #11
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Check this out...
Easiest spot to wire it in is the IGN unfused terminal of the fuseblock.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-25-2010, 09:32 AM   #12
ah_5500
The battery negative is tight. Hopefully today I can mess with it but still not sure. Hopefully something simple, but it never is.
Old 11-25-2010, 10:16 AM   #13
Husker
Husker's Avatar
The bestway to find the problem is to do what Sport/Truck suggested. I had this same problem on My Jeep, it turned out to be the memory wire on my CD deck it was pulling.119ma compared to about .004ma as it should have been. It is the wire that hooks to a positive source that keeps the radio station/clock memory.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 11-25-2010, 10:18 AM   #14
raycow
Definitely disconnect the alternator. Try the red wire on the stud and the plug-in connector separately. Also, does your horn work normally? If not, disconnect the horn relay.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-25-2010, 10:54 AM   #15
Sport/Truck
Sierra Grande Club
Your test light should only barely light and that's if you have a modern stereo with memory. If things are lighting up as you say something is not on the key switch as it should be.
As mentioned by llowlife the alternator can cause a drain when the diode goes bad.
Use your test light and see if it gets dimmer once you unhook the Alt.
With everything coming on as you say I'm wondering if your switch isn't cutting off power like it should?
s/t
Old 11-25-2010, 11:35 AM   #16
swamp rat
swamp rat's Avatar
First things first, as a general rule you should never dissconnect the positive battery cable first because if your wrench touches the body of the truck its gonna spark in a big way, allways dissconnect the negitive lead first, that way your wrench is a ground and so is the body so no spark, Battery vapors are highly explosive and under the right conditions a spark is all it takes to end your hobby and life.
Another thing to try is to pull all the fuses before you let it sit over night, then in the morning put all the fuses back in and see if it fires up. then next night pull all but one fuse, then each night add one more additional fuse back into the fuse block ect, in theory your eliminating each circut one at a time.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-25-2010, 12:22 PM   #17
ah_5500
good thinkin. but i think i figured it out. ill know in a couple days after it sits but im pretty sure it was the horn button wire. the wire had frayed and was grounding on the column. thanks for the info and ideas though. good for future reference bc you never know what youll run into on a 67 model pickup. thanks for the info on the power to my hei as well.
Old 11-25-2010, 04:47 PM   #18
llowlife
Hope you found it....heres the first thing we did when a vehicle came in that had your symptoms....remove the cigarette lighter........worked more often than you would think
