Old 03-04-2003, 10:22 PM   #1
Adron67
Drop spindles
Does any body know how much you would have to drop a 67 chevy to make it evenly droped
Thinking about going 2 1/2 drop spindles in front and 4 inch spring drop in the back
Adrian
Adron67 is offline   Reply With Quote
Old 03-04-2003, 10:26 PM   #2
Dean23
68cst_ss490
Dean23's Avatar
Thats about the same drop i want to do to my 68. I wish I could see a straight on from the side shot of that drop.....
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 03-04-2003, 10:28 PM   #3
Adron67
If you find any picture let me know
Adrian
Old 03-04-2003, 11:05 PM   #4
bigvinnie
bigvinnie's Avatar
try this link....
http://www.earlyclassic.com/sidebyside.html
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 03-05-2003, 12:10 AM   #5
Project1970
14.1 @ 96MPH
Project1970's Avatar
ECE 2.5" spindles and 245/60-15 tires front
ECE 4" drop leaves and 275/60-15 tires rear
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 03-05-2003, 12:22 AM   #6
wlarue72
I am assuming that 275/60/15's won't go in the front with the drop spindles? Just wondering, I plan on doing the same drop.
72 Cheyenne Super 402 daily driver. A lifetime project!
wlarue72 is offline   Reply With Quote
Old 03-05-2003, 02:49 AM   #7
Project1970
14.1 @ 96MPH
The problem isn't the drop, but the wider track from discs. It would depend on your wheels, though, and their backspacing...I think with more backspacing I could run wider fronts, to an extent at least...
Old 03-05-2003, 03:05 AM   #8
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Project 1970 I've got a question, How tall from top to bottom are your tires on the front and the rear. I've got bfg 255/70/15's on all four right now. Thanks in advance
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 03-05-2003, 03:18 AM   #9
Project1970
14.1 @ 96MPH
The rears are 28" tall, the fronts are 26.6" tall.
Old 03-05-2003, 08:13 PM   #10
gmc67swb
gmc67swb's Avatar
Hey PROJECT 1970, where did you get the center caps? I have similar or the same off an '86 Blazer. I need some center caps though. Those are the ones with 3 screws holding them on?
gmc67swb is offline   Reply With Quote
Old 03-05-2003, 08:21 PM   #11
Project1970
14.1 @ 96MPH
Those were the 4x4 ones that came with the rims, just covered with vinyl stickers...
Old 03-05-2003, 11:19 PM   #12
Dreaminator
Dreaminator
I am running 2 1/2 with tweaked front springs that makes the total front drop about 3 1/2 inches. In the back are 4 inch drop coil springs in a carrier adjusted about another 3/4 inch for a total rear drop of about five inches. It sits nearly level with a level placed on the bed. With 17x9 255/60s on the front and 17/9 285/60s on the back I am one inch from top on both fender wells. Off sets are five and one half inches. On my truck the perfect off set would probably be 6 to 6 1/2 inches. Only problem on front was need to adjust stop so tread would not hit stock placed shock. On the back if I go lower and wider I will have to raise and widen the wheel wells inside the bed. Be very careful of the off set. I have already sent two rims back.
The Dreaminator
Daily Driver 1971 Cheyenne 10 Lwb Tilt/Tac 402 .030 TH400.
Dreaminator is offline   Reply With Quote
