body mount component order question
Howdy folks,
When i pulled my cab from the frame the mounts were so rotten that i could not even figure out how many components were involved, let alone the order they fell out of the frame since they broke in so many pieces. I purchased a new gmc pauls kit and the pieces are all quality, but i am not sure why i only have 2 washers that fit on the front bolts and i was hoping to get the cab back on the frame this weekend but he is not answering email until he reopens on monday...... Can anyone tell me if there is supposed to be a washer between the upper half of the body mount and the cab floor? It has always been my understanding that the halves of the mount went around the frame mount, the tube went through them, it was sandwiched by 2 washers, and one washer went against the body while the other washer was against the bolt head or the nut depending on how the bolt went through. I only have 2 washers that fit the larger front bolts, which had me thinking that perhaps the front mount didn't need a washer between the body and mount, but that would mean the tube has to crush and wear against sheet metal. Any ideas? i looked at the lmc picture but it doesn't really spec where the washer sits. Mike Last edited by dyrt; 11-25-2010 at 01:26 PM. Reason: bad grammar. |
Re: body mount component order question
You will need a washer between the mount and the body as you surmised. The instructions that we had with new mounts was to use the existing washer, (which you don't have).
Here is a picture, (extra washer is a shim used to level the cab with the bed). Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
here is the step by step install in the FAQ section
http://67-72chevytrucks.com/vboard/s...d.php?t=192342
In some foreign language "merge" means to stop and turn your head left. My build page http://67chev.shawwebspace.ca/ |
#4 | ||
while we are discussing this, does anyone know the original thickness of the front cab mount washer you are supposed to reuse? i'll just make one, but i have no idea what it looks like or how thick it should be. Mike |
Why the heck would you want toorder a kit that doesn't include the stuff thats normally all rusted and sometimes missing on these trucks. I doesn't make sense that they wouldn't include the washers. Just my opinion. I got to check mine now to see if it came with the washers. Thanks.
#6 | |
Mike |
i just made my own washers and spacers. As it turns out, the newest pdf lcm catalog online list the rear upper washers and front "shim" as being 1/8" and i just assumed that the originals were 3" od, so i made myself those as well as a 3" washer that matches the thickness of the washers supplies with the kit. Now my cab is on the frame and next garage access i get i can start cutting sheetmetal!
![]() Join Date: Oct 2010
what thickness is the first waher on the far left
Chuck ![]() |
