11-25-2010, 01:54 PM | #1 |
People know me
als liner temperature requirements
I looked on the box, instructions, and online and could not find anywhere if there was a temperature requirement for spraying als liner. I am wanting to spray in my garage this saturday or sunday and dont want to waste my time if its not gonna set up right.
It is in the mid teens to 20s right now with snow on the ground. I have a propane heater, but am worried about the fumes in the air, so I would prefer to do it with the garage door opened.
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels 1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels |
11-25-2010, 02:11 PM | #2 |
Re: als liner temperature requirements
i'd think WAY too cold// i wouldnt do it at least until upper 40's minimum
if in doubt i'd wait and contact them for sure
11-25-2010, 02:15 PM | #3 |
People know me
It is a 3 part mixture, so I figured it would just take longer to dry? I did send an email to them as well.
11-25-2010, 04:10 PM | #4 |
IMO... im thinking WAY to cold and i agree with the fumes statment... also im guessing just like other spray in bedliners that you want VENTILATION and LOTS OF IT... i really dont think you want to be breathing the fumes...... wait till ya got a clear day you can open the garage.
11-25-2010, 05:10 PM | #5 |
You can use most roll on, or spray on bed liners down to just above
freezing. The problem is, Most are Xylene based, Or something similar. Which are highly explosive, With a relatively low flashpoint. So I would wait for better weather. Spike
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
11-25-2010, 05:25 PM | #6 |
Sierra Grande Club
Most paints work best at 70*, I'd wait until spring.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
11-26-2010, 03:46 PM | #7 |
People know me
I just wanted to update this thread for anyone searching in the future.
I just recieved this email back from my Al's Dealer: "It is good if you keep the product at room temp overnite and you will have no problem spraying it in your garage. Use the propane heater to warm up the vehicle a bit. It will lay smoother in the colder temps." So I will update this thread again when I get it sprayed on this sunday.
