Will these wheels work?
he wants 75$ fro them, and i was wondering if the bolt pattern would match up, my truck is a 4wd[IMG]
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) Last edited by Youngbuck7072; 11-25-2010 at 03:53 PM. |
Re: Will these wheels work?
if your truck is 8 lug it shouldnt be a problem
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
Grandpa in the rustmobile...
sweet wheels!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
for 75$, definitatley, he said they came off a frod, but should fit. i have no idea
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
Between Trucks...
I'd pass on 16.5" wheels. 16.5" tires cost an arm and a leg.
Beat it to fit, Paint it to match... ![]() |
for that price i'd buy them just to have swapmeet stuff to sell weather i had plans on using them or not
Big Red - Now its a SWB!
Those are some sweet looking old skool wheels.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
Nope wont work, but I need the address and name so I know where they are and to whom recieves payment.
![]() Hell of a deal, I would be all over them.
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
maxxd07, u serious, cause the guy has still got them for sale
Naw, just messin with ya. I think its a good deal so grab them babies up! I would love to have some but dont have anything at the moment to put them on. They will fit your truck and the tires to fit are not that bad to find and/or purchase.
are you sure? the guy said they came off a ford
Ya those wheels should work. The bolt pattern for 8 lug wheels didn't change until ford went to the superduty in like 99 or so they went metric. The difference in the older wheels is the centre hole is bigger but unless your using the wheel to max load rating I think its ok
If you can't impress them with your inteligence, dazzle'm with your stupidity 1969 GMC lwb 2wheel drive can you say big stroker motor to come hehe |
#13 |
I have a set of wheels off of an 92ish f250 and they work fine. The center hole is larger than my hub so they fit sloppy, but are fine when you torque them down. Some say that you may break lugs, but I've had 3600 pounds of gravel loaded in my bed and drove down the freeway and all my lugs are still in place.
#14 |
Yes,they will work and they are worth $75 each.16.5s do not cost an arm and a leg.All tires cost an arm and a leg in the past couple tears since so many diameters have become available.16s are a bit less now (used to be the other way around) and 17s are more.The period correct wheels really set these trucks of like none other.Contemporary custom wheels are what cost an arm and a leg.You can buy a whole lotta tire with the money you'll save on these wheels.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 11-26-2010 at 09:22 AM. |
#15 |
Open this link and scroll down to the 8 lug wheel, read it and then go measure your truck, s/b 6.5" i think but don't quote me, then pull a wheel and measure the backspacing, i'm guessing about4" but again don't quote me. now that you have this information go look at the wheels and take a tape measure, check the lugs and backspacing..
http://www.mrt-wheels.com/boltpattern.html
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#16 |
Back then we never gave backspacing a thought.I never knew what back spacing any of the wheels I ever ran were,never was asked what I needed when buying,nor was asked when selling.They just fit.Things were actually standardized back before the whole wheel/tire thing got so weirded out in recent years.All 8-lug patterns were the same when these wheels were made.
#17 |
Junk Yartist
They will fit. NEVER seen them in the 99+ metric pattern. Only 8X6.5. I have never seen them for less than 200 a set. They are the BEST looking retro aluminum 8 lug IMO.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#18 |
theres a guy around me thats been trying to sell a set of these in 6 lug for a looong time and he wants 150-200 for a set of 4. for 75 they should already be in the garage.
#19 |
so its official, im getting the wheels on monday for $75, plus $10 for delivery
#20 |
8 lug, chevy, dodge and pre 99 ford, are all 8 on 6.5 bolt pattern
#21 |
BlahBlahBlah
Those are cool wheels. A few guys on the board are running them on their 4x4's.
#22 |
Junior Member
I love those wheels.
1. Check center bore and make sure it fits. I have seen studs get bent over center bore being off just a lil especially when tire store cranks them with impact. 2. Make sure lugs are correct length and do not bottom out. Perry PTS |
#23 |
Nothing to see here.....
![]() Join Date: Jun 2007
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
#24 |
16.5 tires are less popular so yes they are slightly more and fewer choices but if you choose a popular tread and size they are not that bad of a deal considering how cool those wheels are!! I have a set of 6 lug 15" ones just likem and they look good to me
#25 |
so i went and talked to a couple guys in the tire buisness today that i trust, and they said not to buy them. they have no bead, so if you roll a tire it will go off the rim, and that these rims are really hard to find tires for, at least the kind i want, so, im not going to buy them
