Old 11-25-2010, 07:04 PM   #1
Red68
Red68's Avatar
Ideas for engine dress-up
I pulled my 327 out of my 68 yesterday and have all of the components to rebuild it except for the "shinny" stuff. Anyone have pictures of there engines all dressed up? I plan to paint it chevrolet orange and have a edlebrock intake and carb. I plan to aluminum valve covers, new plug wires etc.
I am also trying to find wire looms for the spark plugs that will work with center bolt valve covers and stock "ram horn" manifolds.
Any pics would be great
Happy turkey day!!!!
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 11-25-2010, 07:10 PM   #2
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Ideas for engine dress-up
I personally like the looks of the spark plugs routed in the stock location. It gives the motor a clean look.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-25-2010, 07:33 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Here is an idea for an engine.
385 Cubic inch stroker with a 7Qt oil pan and Edelbrock Performer RPM intake and water pump.
Frank
piecesparts is offline   Reply With Quote
Old 11-25-2010, 07:58 PM   #4
Red68
Red68's Avatar
Thanks guys.
I was not sure how to route them, I have the small looms that bolt on the back of the block, where do they go from there? Was there 2 small looms just above where the oil pan bolts to the block?
Old 11-25-2010, 08:08 PM   #5
treveiger
treveiger's Avatar
Not to steel the thread but do the aftermarket shiny stuff have problems with leaking? Ive heard about people having problems with valve covers at least. When its done youll have to give us picks
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 11-25-2010, 08:11 PM   #6
Sport/Truck
Sierra Grande Club
It's been my experience that if it's chrome it going to leak.
s/t
Old 11-25-2010, 08:26 PM   #7
Slick67
Sofa King Crazy!!
Slick67's Avatar
How about a custom air cleaner cover.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 11-25-2010, 08:31 PM   #8
piecesparts
I have been running "shiney stuff" for years. I had some leakage issue with the GM valve covers, until I got the right gaskets, but since then no problem. It all depends on what gaskets and sealer you use and just how cheapof shiney you purchase. If you get the really cheap stuff, it can be warped or pitted and cause leakage.
Frank
Old 11-25-2010, 09:52 PM   #9
hayhauler71
hayhauler71's Avatar
Here is my 350 with edelbrock heads and valve covers also has edelbrock carb
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 11-25-2010, 10:19 PM   #10
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
good luck finding looms for ram horns/centerbolt heads lol
John
1999 Toyota Tacoma 4x4
Old 11-25-2010, 10:32 PM   #11
Sport/Truck
Sierra Grande Club
Originally Posted by Red68 View Post
Thanks guys.
Use those two looms then they run down along side the oil pan (there are some clips) two go up through the motor mounts.
s/t
The small clips are for the plug wires the larger hanger is for the trans cooler lines.
Old 11-25-2010, 10:37 PM   #12
Red68
Red68's Avatar
that is what I was afraid of, I have been thinking about switching to headers but I just had new 2 1/2" exhaust installed so I hate to recut/fit the pipes.
Old 11-25-2010, 10:40 PM   #13
Red68
Red68's Avatar
s/t
I like it, looks good and like you said earlier it keeps them somewhat hidden.
Did you use standard plug wires or did you use the type that you can cut to fit?
Old 11-25-2010, 10:50 PM   #14
Sport/Truck
Sierra Grande Club
The wires in the picture aren't the ones I ended up using (they were too long). So I used them for my measurements, then I ordered from Kingsborne.
s/t
