What to keep off 72 for a 6 lug to 5 lug conversion?
Hey guys I will be going to pick up a 72 for the a/c cab and figured I may as well swap the stuff out for 5 lug. What do I need to keep off the front to convert to a 5 lug? I was thinkin about just unbolting the front crossmember and rolling it under mine.
VA72C10
![]() Join Date: Mar 2008
Re: What to keep off 72 for a 6 lug to 5 lug conversion?
using the entire front crossmember is the best way. Then the rear can also be swapped.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
I just finished doing this on my 68. I just unbolted the entire crossmember and installed it on mine. Did the whole swap in a day.
![]() Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
saving brake booster with braces for it master cylinder and proportioning valve is all good stuff to have
You don't need to swap the crossmember unless you want to. IMO, it is less work to unbolt the control arm shafts and take everything from there on out. Be sure to get the steering linkage too, because the tie rod ends are different.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
