Old 11-25-2010, 11:55 PM   #1
Isanti Lawn Man
Removal of chrome trim
Hello,
Im looking for advice on the easiest way to remove the chrome trim that runs behind the cab on a 72 C10. I would like to remove it without killing it if possible!
Any help much appreciated.
-Mike
Isanti Lawn Man is offline   Reply With Quote
Old 11-26-2010, 09:26 AM   #2
JimKshortstep4x4
Re: Removal of chrome trim
If you are referring to the trim that separates two tone paint then it is fairly easy to remove. The chrome snaps onto plastic clips which are fastened to the cab. Spraying the trim down so as to wet the clips with a penetrant helps the removal process. In removing the trim, I press down on the top of the chrome and lift up on the bottom using a putty blade or similiar flat blade.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
