redo on vent windows
I am redoing my 66 Chevy, I am now doing the vent window gaskets adn windows. when I started the vent windows they had some sort of rivet holdin them in. I drilled out the rivet to replace the gasket. Now when I am reinstalling the gasket what do I use a pop rivet is too big for it. Any help would be appreciated. Thanks
#2 | |
Re: redo on vent windows
http://67-72chevytrucks.com/vboard/s...d.php?t=351471 Good luck. |
get the origanal stuff plus tool for install for around 8 bucks from LMC
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Make sure the rubber is warm before you put them in the vent assy, it is best if you do the rebuild inside where its warm and I put mine in the oven on warm for about 5 minutes before I put them in. Then after that I did the rivets and such.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
