Old 11-26-2010, 04:39 PM   #1
storked82
storked82's Avatar
Torque stick question???
Hello Guys
My question is I have an 82 with aluminum progressive rims what im
Wanting to know is how many pounds of torque to thighten the lug nuts I have a new impact wrench and was also woundering what color torque stick I will need??
Thanks Guys
Jeff Main
storked82 is offline   Reply With Quote
Old 11-26-2010, 06:44 PM   #2
baclay9
Re: Torque stick question???
I tighten mine to 110 ft lbs. I don't know if that is right or not but I have never had a problem. I am interested to see what people say as well. What is a torque stick?
baclay9 is offline   Reply With Quote
Old 11-26-2010, 06:51 PM   #3
3r!c84
Badass
3r!c84's Avatar
There all diffrent colors. Just get the 100ft pounds. Or why not just get a torque wrench and hand tighten it......
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-26-2010, 06:57 PM   #4
red rumbler
red rumbler's Avatar
personally i would use one tbh. if your using it with a air gun your gun has to be up so spec and you must have enough air in the line pressure to make correct torque and even if your using a hand wrachet they get fetigued over time. but just my 2 cents i dont mean to be negative
red rumbler is offline   Reply With Quote
Old 11-26-2010, 07:11 PM   #5
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
buy a touque wrench they are cheap.
touque sticks are not very good i at our shop we had problems before tires comming off
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 11-26-2010, 10:52 PM   #6
datguysaL
yeah get a torque wrench and torque them down by hand.
torque wrenches can last u a good while if u are careful with them.
just dont drop them, and make sure you set them back to 0ft/lb after each use, even if u gonna set it down for just a minute, still set it back to zero.
as far as the specs, i have no idea. it depends by rim manufucturer
and u will have to retorque your wheels after driving a couple miles.
datguysaL is offline   Reply With Quote
Old 11-26-2010, 11:40 PM   #7
babyJay
Arrived on a Pale Horse
babyJay's Avatar
I usually do 90 ft lbs on a 1/2 inch torque wrench. Too much will warp alloy wheels and rotors.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-26-2010, 11:41 PM   #8
babyJay
babyJay's Avatar
Attachments for pneumatic impact drivers.
Jason
89 R3500 CC SRW
Old 11-27-2010, 11:35 AM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
Torque sticks are for those that want speed and NOT accuracy. I don't like torque sticks, because there are too many error points in their use. I purchased a torque wrench and use it religiously on my wheels. If I go on a long trip, I carry it in the truck's bed. My wheels cost me some cash and I am not about to screw up a good rim on a possible error trap. I work at a plant that has equipment to inspect torque wrenches for their accuracy, so I try to get it check on an annual basis.
Frank
piecesparts is offline   Reply With Quote
