check engine light
i have a 91 1500 with a 350. the other day i was driving and the light cam on and a few miles down the road it went off. it has done that for a few days now. well now the light is always on and the truck idles up real high and when i slow down to stop it down shifts really hard. does anyone know what this could be? i was thinkin it might be the tps but im not 100% sure and dont have alot of money to waste on tryin different sensors. thanks for the help in advance.
Re: check engine light
Check to see what trouble code or codes are in memory of the computer.
Here are some web sites with the basics on retrieving codes, on OBD1 systems, without a scan tool or code reader. Poor drawing of ALDL but ok instruction + codes http://www.cfm-tech.com/gm_tbi_trouble_codes.htm OBDI terminal identification http://robertpowersmotorsports.frees.../ALDL_plug.jpg OBDI illustration and instructions http://www.troublecodes.net/GM/ Good explanation http://www.syty.org/old/d&e.html
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
yep its the tps. thanks that first site helped me out alot
just replaced the tps and unhooked the battery. we will see if that fixes it tomorrow when i drive to work
Excellent!
Glad to hear you are making progress. Give us an update after you put a few miles on it.
will do
www.67HEAVEN.com
www.67HEAVEN.com 2004 Z71 Tahoe 4x4 5.3L (factory white monochrome theme) 1989 Silverado K1500 4x4 5.7L sportside (white monochrome theme) 1967 Belair 2-door-post (project) 1967 Corvette 427/435 coupe (now 502/502 red road warrior)
| Bookmarks |
